Looking for 150W handlheld spot light 24V
Polarion-Sparetech2
USA
I have a customer looking for a non-battery powered portable light, 150 W Xenon, 24V DC (military application). ITLasers used to make a comparable product (SET BEAM) but they are out of business. I found comparable product for marine applications but they are fixed position lights. Any help appreciated.
The information I have on original light:
Technical Specification
900 lux (min) at 40 m (narrow beam)
1.0° to 2.5° + SPOT position
150 W short-arc Xenon lamp, IR Filter (Optional)
830 nm cut-on
24V DC standard; high-e‑ciency power switching regulator type
7 ashes/sec Thermal Protection Power cut-owhen Power Supply Unit temperature exceeds +63°C.
Searchlight 320 x 135 x 92 mm
Power Supply
160 x 110 x 230 mm
Remote Control Unit
119 x 32 x 76 mm
Weight
Searchlight
3.2 kg
Power Supply
3.5 kg
Remote Control Unit
0.5 kg
Environmental
Complies with MIL-STD-810
BVH
CentCalCoast
How about the Megaray 175 Watt SA light? It's not a perfect fit but close. Up to a 30-Volt input Voltage, I believe 2 degree beam is minimum expanding to flood, uses a tether to attach to power. When you say "portable" but "non-battery powered", do you mean powered by a long tether or cord that would plug into a military vehicle electrical system?
Other than that, I am not aware of anything fitting the bill.
Polarion-Sparetech2
USA
Yes, I meant plug into a military vehicle electrical system. MR175 meets nearly all of the customer's criteria. Thanks!
