gearvita
- Joined
- May 17, 2018
- Messages
- 129
The Lumintop BLF GT is a very powerful flashlights which has a torch pumps out 2,000 lumens and casts a beam a remarkable 2 kilometers long. Made from hard-anodized aluminum, the light is IP65 waterproof and dustproof to keep the elements at bay. It's also built with enhanced cooling fins to keep temperatures down. To control the light, it's got a single side switch. Hold it down for a few seconds to get maximum output. If you hold it down shortly it steadily ramps up the power.
Main Parameters:
Emitter Type: Cree XHP35 HI
Beam Power: 35 watts high intensity
Flux: >2000 lumens
Peak Beam Intensity: 1,290,000cd (ANSI throw >2000m)
Battery: Four or eight button-top 18650 cells
Waterproof: IP65
Product Features:
● Over 2000m Long Range Beam Distance
With 118mm inner diameter aluminum and smooth finish reflector, it produces a over 2000m throwing distance!
● Cree XHP35 HI LED
35W 2.5A regulated buck with conversion efficiency driver emits around 2000 lumens and 1,290,000 candela, what amazing!
● One Switch Operation
The feature-rich UI provides for smooth ramping of the light output between 0 and 80%, with an easily-accessible 100% Turbo mode.
● Standard Tripod Socket
Can be mounted on a tripod, fit for search, camping, and more.
● IP65 Rated Protection
Against heavy rains and totally dust-proof in sealed condition.
Get this Lumintop BLF GT flashlight from GearVita, you could use it as a searchlight, as a camp light, or as a fun experiment in your backyard (but be careful, as it packs a blinding punch): https://gearvita.com/lumintop-blf-gt-led-flashlight-2000-lumens.html
You may also be interested in:
xiaomi redmi note 5 4g global version
buy xiaomi mi pad 4 plus
Main Parameters:
Flux: >2000 lumens
Waterproof: IP65
Product Features:
● Cree XHP35 HI LED
