No issues right now, but the headlight bulbs on our Tahoe are quite a bit more difficult to change than most vehicles I've owned. Not a BIG deal but still a PITA. As such when I get my next outage I'd like to replace the high beam 9005 and low beam H11 bulbs with something that will offer a good balance between lifespan and output. Historically I tend to use the Philips extreme vision/power bulbs and they do seem to last quite well. But are there better options? The last vehicle with 9005 that I upgraded to TIR (9011) bulbs, they started to burn out after 2 years, although the output was fantastic. Further complicating this, the vehicle (Tahoe) has DRLs which I believe utilize the high beam bulbs but I don't know if they attenuate voltage, amps or use PWM.
Thoughts or suggestions? FWIW, the OE high beams are great, and the low beams are OK but could really use improvement.
Edit: I did find THIS POST which reiterates the 9005-9011 swap as well as a H11-H9 swap which sounds similar to the TIR upgrade. I still question filiment lifespan in both applications, can anybody clarify?
