Imalent RT70 Illuminate The Road And Guarantee Your Safety Outdoors
gearvita
Imalent RT70 is a portable USB magnetically charged high performance flashlight - a smart aid for night outdoor searching and rescuing and industrial tasks, as well as a backup lighting tool for your self-driving journeys. Six output levels and hide strobe, ensures you can have long runtime with low output or high output when needed, so you can plan and prepare for your nighttime outdoor journeys and activities well in advance. RT70 is fitted with one latest upgraded Cree XHP70 2nd generation LED, delivering 5500 lumens of output and a beam distance of 903 meters. Considering the user interface, the RT70 is fitted with user-friendly side pressure switch for stepped light regulation to control the runtime and output selection. This versatile light caters for multiple output level demands.
Main Parameters:
Emitter Type: XHP70.2
Max Output: 5500 lumens
Beam Range: 903m
Peak Beam Intensity: 203800cd
Battery Configurations: 4 × 18650 battery
Waterproof: IPX-8 standard (underwater 2m)
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 5500-3300 lumens ( 8+96min )
High: 3300 lumens ( 110min )
Middle High: 1200 lumens ( 3h 45min )
Middle: 800 lumens ( 7h 18min )
Middle Low: 400 lumens ( 18h 18min )
Low: 60 lumens ( 96h )
Product Features:
● Utilizes one American Cree XHP70 2nd generation LED, with a lifespan of up to 50000 hours and a maximum output of 5500 lumens.
● Built-in safety self testing intelligent charging circuit, convenient, fast and safe.
● Six levels which can be exchanged quickly and instant Turbo.
● Battery capacity indicators besides power switch, shows the capacity any time.
● High efficiency constant current circuit will maintain constant brightness.
● Built-in magnetic charging, high grade and portable.
● Built-in thermal control module will automatically adjust the brightness output, keep using comfortably.
● Combination of toughened ultra-clear mineral and anti-reflective coating glass
● Aluminium OP reflector
● Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment.
● IPX-8 standard waterproof (2 metres submersible).
Priced at $137.99 on GearVita, Imalent RT70 is a high performance flashlight you deserve, to guarantee your safety outdoors, no matter walking or driving: https://gearvita.com/imalent-rt70-led-flashlight-5500-lumens.html
You may like:
xiaomi mi 8 lite 64gb smartphone global version
xiaomi mijia quartz smartwatch
