Hello.
I have an Olight H15S headlamp with a broken battery case. The locking tabs on the case are unfortunately broken off and I'm considering just cutting the case away and add a connector, so I can use a FatShark FSV1814 battery case. But before I do that I have to know if the H15S electronics will withstand the voltage from a 2S battery pack. Of course, I could just run two 18650 in parallel, but just adding the FSV1814 (2x 18650 in series) would be quite a nice and easy solution. Is there someone here who confirm whether or not the electronics in the H15S will survive the voltage of 2S lipo?
Thanks.
Thanks.
