Nitecore MH12GTS - Ultra Compact Dual-fuel Searchlight Up to 1800 Lumens
gearvita
The Nitecore MH12GTS is an incredibly powerful LED searchlight, with a size to brightness ratio that will astound you! Measuring at just over five and a half inches, this portable powerhouse can emit up to 1800 lumens! Utilizes a Cree XHP35 HD LED and either two CR123A batteries or a single 18650 along with precision optics to deliver an impeccably bright and far reaching beam. The beam of this light can reach over 740 feet, with 5 brightness levels and 3 special modes to choose from, making it a great choice for late night hunting, hiking and especially search and rescue operations.
Main Parameters:
LED: Cree XHP35 HD
Max Output: 1800 lumens
Peak Beam Distance: 226 meters
Peak Beam Intensity: 12760cd
Power Source: 1 × 18650 or 2 × CR123A battery
Waterproof Rating: IPX-8 (2 meter submersible)
Impact Resistance: 1 meter
Output and Runtime (using 1 × 18650 battery):
Turbo: 1800 lumens ( 30min )
High: 900 lumens ( 2h 15min )
Mid: 240 lumens ( 5h 45min )
Low: 70 lumens ( 19h )
Ultralow: 1 lumen ( 250h )
Strobe/Beacon/SOS: 1800 lumens ( / )
Product Features:
● Utilizes XHP35 HD LED, with a lifespan of 50000 hours and maximum output of 1800 lumens.
● Maximum peak beam intensity of 12670cd and maximum throw of 226m.
● Optical system combined with crystal coating and precision digital optics technology.
● High effciency constant circuit provides stable output up to 250 hours.
● Metal side switch controls 5 brightness levels and 3 special modes.
● Power indicator beneath the side switch indicates the remaining battery power.
● Power indicator can also display the battery voltage.
● Built-in Li-ion battery charging circuit with a micro-USB port.
● Rigid double layer tube design.
● Incorporated advanced temperature regulation module and electronic reverse polarity protection.
● Optical lenses with double-sided scratch resistant coating.
● Constructed from aero grade aluminum alloy with HA Ⅲmillitary grade hard-anodized finish.
● Waterproof in accordance with IPX8 (2 meters submersible), and impact resistant to 1 meter.
● Tail stand capable.
The $82.99 Nitecore MH12GTS on GearVita is the brighter upgrade to the MH12GT, it is a powerful searchlight that versatile enough for everyday tasks: https://gearvita.com/nitecore-mh12gts-led-flashlight-1800-lumens.html
You may also interested in:
xiaomi mi box s global version
xiaomi redmi 6a global version
