Yeelight YLFW01YL Candela Light - Ignite The Romance with A Single Rotation
gearvita
Yeelight YLFW01YL Candela Light features metal candlestick base design with brass lampwick, full of sense of art, can present you an unrivalled visual experience. It adopts BLE Mesh technology, allowing up to 30,000 units candelas to communicate with each other. The LED candela light with compact and lightweight design, portable to carry, can bring you a warm and cozy vibe for your bedroom, living room, workplace and etc.
Product Features:
● Candela Light
Metal candlestick base design with brass lampwick, full of sense of art, can present you an unrivalled visual experience.
● Stepless Dimmable
Clockwise and counterclockwise rotate the lamp to adjust the light brightness, easy to operate.
● BLE Mesh Technology
Allows up to 30,000 units candelas to communicate with each other. If you rotate one lamp, other candela lamps will automatically change the brightness at the same time.
● Warm Light
Holds a 1600K color temperature, the same color temperature as a candlelight, will not hurt your eyes, brings a warm and cozy lighting atmosphere.
● Long-lasting Life
Built-in 2100mAh lithium battery, allows for up to 8 hours of continuous use after a full charge. Hidden USB charging port, protect the plug from external impact force.
● Smart Control
You can control your candela light and other Yeelight smart lights by your phone via Yeelight app, making your life easier.
● Distinctive Design
The glass like naturally transparent poly-carbonate (PC) lamp chimney tube allows light to distribute evenly and beautifully.
Candela is the world's only smart candlelight using the latest Bluetooth (BLE) Mesh technology, combining the warm comfort of candlelight with the convenience and control of smart technology. Do you want to make your place more attractive and create a warm and soft atmosphere to those who you love? Come to GearVita, here is your ideal choice: https://gearvita.com/yeelight-ylfw0...support-bluetooth-control-global-version.html
You may like:
buy xiaomi 70 minutes smart wifi car dvr
buy xiaomi mi band 3 smart bracelet heart rate monitor
