Modding a D1S with the White Flat 2mm^2
staticx57
NJ
We start off with the light opened and the wires already unsoldered but no changes yet
Old LED on the star removed and the replacement still in its packaging
Now we need to heat it up and remove the old LED and replace with the new
Close up
Post reflow testing
Problem?
Solution
Quick picture before we connect it all up
Test inside the light under its own power
All closed up
Quick and dirty beamshot. In this case it is two D1S, modded and not modded
knucklegary
NorCal, Central Coast
Childs play with the right equipment and knowledge to use it correctly
* I heard from a reliable source W1/W2 will be offered from Emisar soon:thumbsup:
aginthelaw
NJ, USA
Are you going to have some numbers on this soon...My palms are starting to sweat
P. S. why did you pick the d1 over the d1s?
staticx57
NJ
Thanks all! :D
againthelaw, this is most definitely a D1S not a D1.
