HKJ
[size=+3]Enerpower 26650 3.2V 3000mAh (Blue)[/size]
Official specifications:
LiFePO4 cells in 26650 format, they can deliver a fairly high current.
The two cells has fairly well matching discharge curves and they have flat output voltage because they are LiFePO4.
[size=+3]Conclusion[/size]
These batteries do not have high capacity, but they can deliver a lot of current and output voltage is stable around 3V.
[size=+3]Notes and links[/size]
The batteries was supplied by batteridoktorn.se for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
- Chemistry: LiFePo4
- Format: 26650
- Brand: ENERpower
- Manufacturer: Heter
- UL: MH48108
- Name: HTCFR26650-3000mAh-3.2V
- Nominal voltage: 3.2V
- Discharge Voltage: 2.5V
- End-of-Charge Voltage: 3.6V
- Maximum charging current: 9A
- Capacity: 3000 mAh
- Continuous load (in amperes): 10C (approx. 30A)
- Internal resistance:<15m?
- Pulse Load: 45A / 5 Seconds
- Weight: 85 g.
- Dimensions: 26.15 mm diameter / 65.60 mm length
- Protective circuit: NONE
- Lifetime: 2000 full cycles (100% DOD) / 4000 full cycles (80% DoD) / 6000 full cycles (60% DOD)
