XTAR AWESOME VC2S CHARGER!!
XTAR Light
Vendor
China
WOW!! This is Xtar VC2S charger which intelligent display of charging !!
Upgraded colorful VA LCD screen tells you real-time charging status!
Intelligent Visible Experience
Micro-USB powered, charge anywhere
Internal Resistance Testing
Portable Power Bank Function
Battery Type Auto-identification
0V Activation Function revives over-discharged battery
Soft Start& TC-CC-CV Three-Stage Charging
This is the awesome upgraded colorful VA LCD screen battery charger which can tells you real-time charging status!
Press the buttom to switch the display of CAP(charging capacity, CCR(real-time charging current) and IR (internal resistance)).
When you reverse polarity happens, the screen will show "Err" to remind you insert the battery correctly.
Micro USB input port available with all 5V USB power, You can charge batteries anywhere and anytime. Share one adapter with your phone, cost-effective and eco-friendly.
Charge USB devices and the batteries at the same time. Or unplug the power supply, inset Li-ion battery in the slots to charge USB device as a power bank, Both slots can be used for charging devices, But it will discharge the battery in left slots preferentially by default.
➡️Click here to know more: XTAR|Battery&Charger&Flashlight
Business inquiry email: [email protected]
Join XTAR Group: XTAR Good Times
