Sold/Expired ALL SOLD: 365mn UV Aleph & McGizmo Light Engines
datiLED
Atlanta, GA
All SOLD. Thanks CPF!
For sale are the following light engines using the Luminus SST-10 365nm UV LED:
These Luminus SST-10 365nm UV light engines are perfect for currency and ID verification, curing Norland 61, scorpion hunting, finding pet stains, inspecting hotels for cleanliness, etc. The Luminus SST-10 365nm UV LED is a real performer with high output and low visible light, with approximately 900mW-1000mW radiant flux @ 700mA (aluminum cans), or 1200mW-1400mW radiant flux @ 1050mA (copper cans). All have three level datiLED AMC3s converters with a 2.8V-5V operating range for use with a single 3.7V RCR cell.
1. Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 1050mA high in solid copper can. $90 SOLD
2. Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 1050mA high in solid copper can. $90 SOLD
3. Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 1050mA high in solid copper can. $90 SOLD
4. Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 700mA high in aluminum can. $78 SOLD
5. Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 700mA high in aluminum can. $78 SOLD
All LEDs are mounted on Noctigon direct thermal path copper MCPCBs. For the copper cans, the LED and copper MCPCB are soldered onto the copper can in a single operation, effectively creating a direct thermal path to the can itself. The aluminum cans have the copper MCPCB attached with thermal epoxy.
The first "I'll take it" posted here takes preference over PM.
In addition to an "I'll take it", you must also acknowledge that you understand the dangers of UV, and are prepared to protect yourself and others. Please consider using the following statement kindly crafted by Carpe Diem: I do understand the dangers of UV lights, and am prepared to protect myself and others regarding the same.
maxspeeds
Oahu, Hawaii
Re: FS: 365mn UV Aleph & McGizmo Light Engines
These look great and have a small led. Can they fit behind a haiku reflector?
edit: If they can, I'll take #1
PayPal Sent
Dakine234
Hawaii
I'll take #2 please!
Nimitz68
USA
I'll take #3 please. I do understand the dangers of UV lights, and am prepared to protect myself and others regarding the same.
datiLED
Atlanta, GA
Yes, the LED is the standard 3535 LED package. It will fit the Haiku XP reflector.
PM sent. Thank you.
PM sent. Thank you.
PM sent. Thank you.
Nimitz68
USA
PayPal payment sent. Thanks!
maxspeeds
Oahu, Hawaii
PayPal Sent
RPM
So. Cal
I'll take #4 "Luminus SST-10 365nm UV with 3 level datiLED AMC3s converter, 700mA high in aluminum can"
and... I do understand the dangers of UV lights, and am prepared to protect myself and others regarding the same.
Paypal ready.
R-
datiLED
Atlanta, GA
Paypal ready.
R-
PM sent. Thank you.
RPM
So. Cal
#4 Received.
Thanks for the quick shipment.
Now off to Arizona to hunt for scorpions!
Creepy little buggers.
R-
