Hello. I'm a total newbie when it comes to flashlights but want to try out an Emisar D4 as was recommended by a few members. My concern is the unprotected battery it requires and the dangers I keep reading about.
I will be using a NiteCore D2 charger for this battery. I've read that if these unprotected cells are drained too much then it can cause issues (gas, fire, etc) to the battery, specifically while it is recharging. I've read the D4 has internal voltage cutoff of 2.8v, but this seems too low of a drain as per what most recommend.
Can someone shed some light?
