HKJ
[size=+3]Eizfan IMR18650 3100mAh (Black-cyan) 2018[/size]
Official specifications:
This is a 18650 battery with good capacity rated for high current.
The discharge curves tracks nicely, but the battery gets fairly hot at high discharge currents.
[size=+3]Conclusion[/size]
The cell has good capacity (slight below 3100mAH) and good high current ability for the capacity, but the current rating is way to optimistic.
[size=+3]Notes and links[/size]
The batteries was supplied by Eizfan (Efan) for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
- Capacity: 3100mAh
- Nominal Voltage: 3.70V
- Standard Charge: 1550mA, 4.20V, 50mA cut-off
- Fast Charge: 4000mA, 4.20V± 0.05V, 100mA cut-off
- Max. Charge Voltage: 4.20V
- Max. Charge Current : 4000mA
- Standard Discharge: 500mA
- End voltage (Cut off): 2.5V
- Max. Discharge Current: 40A
- Weight: Max. 48.0g
- Operating Temperature: Charge: 0°C ~ 50°C, Discharge: -20°C ~ 60°C
- Storage Temperature: 1 month: -20°C ~ 60°C, 3 months: -20°C ~ 45°C, 1 year: -20 ~ 20°C
