CandlePowerForums
Go Back   CandlePowerForums > Flashlights > Flashlight Electronics - Batteries Included
CPF Only
User Name
Password
Register
Click For More Details of D10 sp.
Reply
Thread Tools Display Modes
  #1
Old 01-22-2007, 08:19 AM
SilverFox's Avatar
SilverFox SilverFox is offline
Silver Moderator
Arrow Eneloop Self Discharge study
Sanyo started the ball rolling with low self discharge NiMh cells with the introduction of their Eneloop cells. I, along with several others, have been testing these cells for roughly a year now and they seem to be holding up to the manufacturers claims.
Sanyo claims 2000 mAh for their AA cells, and we are finding that to be very close. Sanyo claims that they can be used right off the shelf, and that also seems to be true. Sanyo also claims a cycle life of 1000 charge/discharge cycles. I would love to be in a position to check this out, but, for now at least, we will just have to believe them on this. The final claim is that they will still have 85% of their initial capacity after 1 year of room temperature storage.
This is what I found:
Here is the initial test data on these cells
You can see that they are very strong performers. I even included the data from the 30 day self discharge for comparison.
I then took a pair of cells and stored them on a shelf in my house. Data was taken at 0, 30, 90, and 180 days. Here is what that data looks like.
You can see that the biggest drop in capacity comes in the first 30 days. After that, things settle down. Looking at the numbers we have about 93% of the initial Amp Hours after 30 days and about 91% of the initial Watt Hours for the same time period. At 90 days we have about 88% of the initial Amp Hours and about 85% of the initial Watt Hours. At 180 days we have about 86% of the initial Amp Hours and about 82% of the initial Watt Hours.
I can easily see how these cells could still have 85% of their initial capacity at the end of a year. I am only going to project out to the year mark because I am going to be using my cells. Someone else can do the 1 year testing…
I did not note the voltage of the cells at 30 and 90 days, but at 180 days each cell was at 1.313 open circuit resting volts.
Update: 3/17/08
I just finished testing a set of 9 cells that I normally use in my Mag85. I set them aside a year ago and just finished testing them. Under a 1 amp load, they came in at 1578 mAh. Initially they came in at 1871 mAh, so you can see that they did not live up to their 85% remaining charge after a year of storage.
However, 84.34% is pretty close...
Several people have reported their self discharge test results and they seem to be quite low for normal NiMh cells. A lot of published information has NiMh cells in the 0.5-1% per day self discharge range. I was seeing around 0.7% per day with several brands of cells, based on short term tests of around 30 days. This seems to still be a little high for healthy cells. The problem 2500 mAh cells will completely self discharge in around 10 days so keep in mind that I do not consider those cells “healthy.”
Here is a graph of NiMh self discharge rates comparing original cell chemistry to the Eneloop cell chemistry.
The 0.7% per day line is pretty close to what I, and others, have reported, but it seems to be pessimistic at 90 days and beyond.
The question of the suitability of the Eneloop cells for use in a remote control or other low drain device has often come up. We know that the self discharge rate is faster early on, then it tapers off. I was concerned that there would be little difference between the normal chemistry rate and the Eneloop chemistry rate, initially, and there might be little advantage in using the Eneloop cells in applications like this. This study indicates that even at the 30 day self discharge rate, the Eneloop chemistry is a lot better.
Ray (Codeman) ran some discharge tests on some Eneloop cells that had been stored for 12 months. The have a manufacturing date indicating that they are 19 months old. You can find his results in this post. Thanks Ray.
Unfortunately we don't know how much charge they initially had. Sanyo Europe stated that they were putting around a 70% charge into the cells, and we are assuming that this practice is universal, and has been in place since the cells were first introduced.
MorePower sent me some RayOVac Hybrid cells to check out. Thanks.
I will be following the same testing proceedure I used for the Eneloop cells.
Here are the initial test results.
Here are the results from the self discharge study on the Hybrid cells. I will add data as it becomes available. I am using the same storage and testing conditions as I did with the Eneloop cells. The test results are from a 0.50 Amp test.
The Hybrid cells are better than normal NiMh cells, but not quite as good as the Sanyo cells.
Cannesahs picked up some GP ReCyko AA cells for me. Thanks Jyrki.
The capacity of the battery was not labeled, so I guessed at 2050 mAh. EDIT: They are labeled as 2100 mAh and 2050 mAh minimum. ENDEDIT These are very strong cells. I was surprised that they almost held up over 1.0 volts at 10 amps. I think the voltage of the Eneloop cells is a little higher, but these are very strong cells.
Here is the initial data.
It will be interesting to see what their self discharge rate is. Testing in progress...
Here is some test data from the Eneloop AAA cells.
And here is the self discharge study on these cells.
There doesn't seem to be much self discharge between 30 and 90 days. The odd numbers are from slight differences in the cells. I used 4 cells for these tests and rotated them in pairs for the various test periods.
Update 5/23/2009
In March of 2006 I ordered and set aside some AAA Eneloop cells. I just got around to needing them and decided to see what they had left in them as far as capacity goes. Over the last three years they have been stored at room temperature.
They ended up with about 550 mAh left. This is about 74% of their original capacity...
Not too bad...
Tom
__________________
Behind every Great man there's always a woman rolling her eyes...
Most batteries don't die - they are tortured to near death, then murdered...
  #2
Old 01-22-2007, 10:38 AM
Anders Anders is offline
Default Re: Eneloop Self Discharge study
Hello Silverfox.
Thx a lot for your time and effort to do this and all the other tests for us here at CPF.
I just ordered some more Eneloop cells
Useful information as always, thanks again
Anders
  #3
Old 01-22-2007, 11:53 AM
Codeman's Avatar
Codeman Codeman is offline
Thanks for all the hard work Tom! I think it's time to start swapping out cells in my hotwire lights.
__________________
Ray
Good people need to be there for each other. It's the only way to stay sane in a sometimes insane world.
  #4
Old 01-22-2007, 11:55 AM
wasBlinded wasBlinded is offline
I have 4 Ray-O-Vac Hybrid cells and 4 Eneloop cels that I did a "Refresh-Analyze" on the MAHA c-9000. I plan to let them sit for 30 days (end of the month) and do a discharge test on them. It will be interesting to see if the Eneloops match your results, and how the Hybrids compare over that period.
  #5
Old 01-22-2007, 11:57 AM
Robstorch Robstorch is offline
Great work! But some of us consider it fun using our chargers more often!
__________________
Streamlight ProPolymer Luxeon, Dorcy Metal Gear, Radio shack Spotlight, Panasonic Bq-390 chargers,energizer AA folding lantern.
Camera reviews at www.imaging-resource.com
  #6
Old 01-22-2007, 11:59 AM
Brighteyez Brighteyez is offline
Thanks for all the work, Tom. That's great info to have, very useful.
  #7
Forgot to ask, not sure if you know or not how the eneloops handle fast charging with the Energizer 15 minute charger?
__________________
  #8
Old 01-22-2007, 12:20 PM
coppertrail's Avatar
coppertrail coppertrail is offline
Yes, this is really great information. Thanks for taking the time to complete this study
  #9
Old 01-22-2007, 12:32 PM
Idunno445 Idunno445 is offline
Unenlightened
Great info SilverFox! Thanks for doing this!
Nick
  #10
Old 01-22-2007, 12:40 PM
I think Tom mentioned in another thread that they work fine with the 15 minute chargers, but those chargers do take a toll on the overall life of the batteries.
Quote:
  #11
Old 01-22-2007, 01:01 PM
HashPipeK HashPipeK is offline
Unenlightened
Nice to see, I wonder how the Rayovac Hybrids compare.
  #12
Old 01-22-2007, 01:59 PM
Bearcat Bearcat is offline
I sure would like to see a heads-up comparision between the Eneloops and Rayovac Hybrids. Hopefully, they will be close to the same, since I loaded up with Hybrids for $3.87 per package of 4-AAs and I used up all 10 of my $5.00 off coupons.
  #13
Old 01-22-2007, 02:15 PM
Phaserburn's Avatar
Phaserburn Phaserburn is offline
*Flashaholic*
Fantastic work and great news! I am more than happy with this rate of charge retention. Knowing I can count on 86% of a full charge after 6 months is terrific; it takes all of the mental overhead out when trying to remember (or worse, write down) when specific cells were last charged. If you just assume you have around 1.7Ah or so to play with regardless of when they were charged, you'll be in the ball park for your calculated runtimes. Not too shabby.
__________________
The Phaser: A nice EDC with great throw; heat and runtime can be issues.
  #14
Old 01-22-2007, 02:45 PM
jezzyp's Avatar
jezzyp jezzyp is offline
I think that a lot of CPFs will now buy a lot of eneloops - and tell others to buy them.
Its just a shame that Sanyo will never reward Silverfox for massivly upping their sales.
Still at least we appreciate the work done.
__________________
We call them torches here in England...
  #15
Old 01-22-2007, 02:57 PM
Bullseye00's Avatar
Bullseye00 Bullseye00 is offline
It'd be nice to get a comparison of all the major low self-discharge NiMh batteries, but SilverFox is probably tired of super long-term self-discharge testing about now. Maybe if people would donate the the batteries to him, we could persuade him to do another round of testing.
  #16
Old 01-22-2007, 06:18 PM
dekelsey61 dekelsey61 is offline
Tom,
Thank you for all your imformation!! Thank you for all your hard work also.
Dan
  #17
Old 01-26-2007, 11:36 AM
Perfectionist Perfectionist is offline
Great work !
So are the Sanyo 2000mah Eneloop's mah better than the Uniross 2100 mah Hybrio's ??
  #18
Old 01-26-2007, 10:23 PM
etc etc is offline
Interesting. So they discharge slower, much slower than conventional Ni-MH.
Question: Given the lower 2,000 MaH capacity, does it mean one will get more recharge cycles than the higher capacity 2700 MaH cells?
  #19
Old 01-27-2007, 08:28 AM
SilverFox's Avatar
Silver Moderator
hello Etc,
Sanyo advertises 1000 cycles, without specifics...
Tom
__________________
  #20
Old 01-29-2007, 08:21 AM
Eugene Eugene is offline
They self-discharge slower to be correct. And yes they should last for more cycles, fewer charge cycles is one of the tradeoff's of the higher mAH batteries.
I've bought a few and have had a set in our digicam for a couple weeks now which is so far better than regular NiMH's which would self trigger the low battery after a couple weeks.
  #21
Old 01-31-2007, 01:00 AM
Canuke Canuke is offline
Quote:
Especially when one factors in the additional charge cycles *necessitated by self-discharge* that the Eneloops won't need.
  #22
Old 01-31-2007, 02:02 AM
roadie's Avatar
roadie roadie is offline
Silverfox Well Done !!
Thank you for yr in-depth study of the eneloop, really open my eyes ....
i will be using the eneloop for my upcoming magmod .....
as its hard to source for high discharge nimh which is "cheap" like eneloop as compare to R/C sub C batteries in Singapore ....
  #23
Old 01-31-2007, 07:04 AM
Phaserburn's Avatar
*Flashaholic*
Quote:
Very good point. I as many cycles are put on a cell because of self-discharge as actual use.
__________________
  #24
Old 01-31-2007, 08:12 AM
MrAl's Avatar
MrAl MrAl is offline
Hello,
I see 1000 cycles on most of the NiMH cells i see on the web.
The wording is 1000 cycles to 80 percent capacity.
If this is really true, these are great batteries!
I have by doubts though, but i wont say anything until i've seen for myself.
BTW, in my quest for the best batteries, best flashlight, best LEDs, i forgot to
take the time to say thanks to Tom for all his hard work with the testing of
the various cells...i know it's not easy because i've done some of it myself and
it is very time consuming and you have to make sure you get everything right or
the results will not be valid, so thanks very much Tom for taking the time to
do this, which benefits all of us who care about our lights and cells.
__________________
Take care,
Al
LED's vs Bulbs, the battle is on.
My bumper sticker: "I Brake for LED's"
To err is human, to theorize divine.
Got Light?
  #25
Old 01-31-2007, 08:56 AM
SilverFox's Avatar
Silver Moderator
Hello Al,
Cycle life is defined as the number of cycles it takes to get to 80% of initial capacity utilizing a standard charge of 0.1 C for 16 hours followed by a 5 hour discharge. All of this is done at standard laboratory temperature conditions.
The Battery Handbook states that NiMh chemistry is good for roughly 500 cycles under these conditions.
Now, if you only do a partial discharge most of the time, your cycle life can exceed 1000 cycles. Duracell did some studies where they charged cells to 85% of full capacity and cycled the middle 60% of the cells capacity. They got excellent cycle life, in the laboratory.
Tom
__________________
  #26
Old 01-31-2007, 09:21 AM
bp044 bp044 is offline
I agree with MrAl's quest to have the best batteries.flashlights and led's.He does not mention a desire the have the best charger. Iwomder if he and others would help me out with a list of their " best "or favorite chargers.Particularly for use with Eneloop's
  #27
Old 02-01-2007, 12:03 PM
3rdDerivative 3rdDerivative is offline
My results after 6 weeks self-discharge:
Sanyo 2700mha -latest from TD (superlattice alloy EVO) --- 2313
Eneloop AA --- 1782
So 2700 still winning overall at 6 weeks. Hmm. Are these latest 2700mah Sanyo's really that good?
Note: 6 weeks of self-discharge, tested on Maha C9000 at 400ma discharge rate. Storage 72F or lower.
  #28
Old 02-01-2007, 12:20 PM
paulr paulr is offline
A note on capacity: I just acquired a 4-pack of AAA eneloops (thanks to Coppertrail), mfgr date apparently 8/2006. I put one into a 1aaa flashlight (L0P CE) and ran it to exhaustion, then plopped it into my BC900 (initial voltage displayed: 0.86 V) and fully charged it at 200 mA (C/4 nominal). Total charge taken was 850 mAH which I suspect means the actual capacity of this cell is somewhere south of 750 mAH.
I put a second AAA eneloop in the light and used it for a while, I'd have thought maybe to 50% or so. I then put it in the BC900 and the measured voltage was 1.24V which in my experience with HR-3U AA cells has meant the cell is about ready for a recharge. After a couple hours the cell was at 1.55V and somewhat warm. I thought the BC900 should shut down if the voltage got anywhere near that high. I suspect the BC900 missed termination. Anyway I pulled the cell out and I hope it's not damaged. It's in the light right now and seems to be working ok.
  #29
Old 02-01-2007, 12:59 PM
Mike abcd Mike abcd is offline
I've seen AAA cells hit 1.60 V regualrly charging on the BC-900 without missing termination. I doubt your Eneloop missed charge termination although it was probably close to fully charged.
Mike
  #30
Old 02-01-2007, 01:20 PM
Hmm, interesting, I'm more used to AA's and I didn't realize AAA's acted differently. Thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
