CandlePowerForums
All "reviews" threads are to be posted within their applicable forums. If administrators or moderators wish to have them published in the Reviews forum, they will move them there. If the reviewer, when posting, wishes to request inclusion in the Reviews forum, they may attach a notice as the first line in their post such as "for submission in the Reviews forum". Alternatively, they can omit such a first line, and simply PM a moderator or administrator asking that it be considered.
Go Back   CandlePowerForums > Flashlights > Flashlight Reviews
CPF Only
User Name
Password
Register
Advertising on CPF!
Reply
Thread Tools Display Modes
  #1
Old 01-30-2007, 12:55 PM
tenfour's Avatar
tenfour tenfour is offline
Default DealExtreme U2 "fake" review (Lux version)
FIRST I will say that these types of lights spark lots of controversy. This review is purely observational - based on functionality. Forget about price, manufacturer, or other emotional / philosophical comments.
I KINDLY ASK THAT IF YOU WANT TO ARGUE THE MORAL / ETHICAL / EMOTIONAL / PHILOSOPHICAL DETAILS OF RIPPING OFF THE SUREFIRE DESIGN/NAME, START YOUR OWN THREAD. It's all been heard before, and I'd hate to see a technical review thread turn into the same old mush of complaining.
Ok I finally received the DealExtreme U2 clone. Ordered 1/18/2007, Received 1/30/2007.
It looks almost EXACTLY like a U2. SureFire logo and everything.
- It has a cheapy thin glass lens
- Smooth reflector
- No pocket clip
- tail clicky works differently than U2 and is difficult to use
- the "selector ring" is just for show, it doesn't even move
- 18650's work just fine in both modes
I have no way to do a runtime graph so don't expect that.
The light has 2 levels. The first level is just about equivelant to the U2's higest (level 6) mode.
The 2nd level is about equivelant to the U2's level 4 mode.
The parts fit together well. None of them are loc-tite'd. The "selector ring" is glued onto the body; i could not remove it (in fact i broke my vice trying)
The tail clicky sucks. You have to press it at like a certain angle to make it click, otherwise it feels like it jams and won't budge. Gross.
There is no momentary-on... 1st click = high level, 2nd click = low level, click again = off. The only gripe about the UI is that the light turns on when the switch is on its way back OUT. So, when you press it IN, the light is still off. When you let go of the switch, then it turns on (reverse clicky).
EDIT: The tail cap can be fixed - it can be disassembled from the inside, and there are lots of loose-fitting parts. Mine were all shoved off to the side, making the switch barely work. centering them made it work just fine, but i have yet to actually secure the parts centered. some other time when i'm not so lazy i guess...
If you remove the reflector, you can get a really nice wide clean flood of light - I might actually prefer it this way for some things.
EDIT: a few more comments:
- the tailcap is not compatible with the U2, and vice-versa
- the beam is pretty good. a little messy, but no big holes, donuts, stuff like that. there's less spill than a U2, and a tighter hot spot.
- the "selector ring" is aluminum
- the light is cast, not machined.
EDIT (2nd revision): Water resistancy. I dunked the light under my full kitchen sink of water for a few minutes, clicking like mad on the switch. SEEMED to work like a charm, but found that the LED was just barely lit while the light was off. I opened the tailcap again and found that water had gotten into the switch. So, it's NOT water resistant unless you find a way to seal the tailcap rubber.
Pictures... Note that my U2 is a lux lotter loser, and I have a relatively blue beam as it is.
Here is the packaging.
Inside the white box, the light was taped in bubble paper:
Compared to my U2. The clone is on top. Yep that's the surefire logo there, and surefire-looking serial number. The serial number is fake. Other people that have purchased this light also got A02621...
Compared to my U2 again. The clone is the top one.
Down the barrel!
Again.
Tail clicky is shorter. Notice the surefire.com link there... Also note that my U2 has Nekomane's z58 tailguard on it. That mod will not work with this clone, because the tailcap is all 1 piece.
Head assembly; apologies for the blur.
Without the reflector. Looks like an easy modee...
The tail cap - notice there is no spring. That is a spring-loaded piece of metal there.
Down the battery shaft. The head does not detach like the U2's. I am using my U2 to light the tube =)
Again...
High level, 1 meter away.
Real U2 on the left
Clone U2 on the right
High level, 1 meter away - exposure 1/1000 sec to compare beams.
Real U2 on the left
Low level, 1 meter away
Real U2 on the left (at level 4)
Clone U2 on the right (on low level)
Low level, 1 meter away - exposure 1/1000 sec to compare beams.
Real U2 on the left
  #2
Old 01-30-2007, 01:08 PM
Art Vandelay's Avatar
Art Vandelay Art Vandelay is offline
Default Re: DealExtreme U2 clone review (Lux version)
I feel sorry for anybody who buys these second hand, thinking they are getting a real Surefire. I've seen copies before, but this is counterfeit. They put the Surefire label on the side, good grief!
  #3
Old 01-30-2007, 01:26 PM
KROMATICS's Avatar
KROMATICS KROMATICS is offline
Thumbs down Re: DealExtreme U2 clone review (Lux version)
Quote:
Unbelievable. It was bad enough they copied the U2 design. With the Surefire logo and url there can be no doubt it was specifically designed for scamming people. Companies like this are despicable and should not be given our business. I wonder if Surefire can sue them as it's apparently Thunderdome over in China as far as IP is concerned.
__________________
KROMA
TICS
  #4
Old 01-30-2007, 01:29 PM
Mr_Light's Avatar
Mr_Light Mr_Light is offline
Two things:
I wonder if the reflector is deep enough for a CREE star swap?
Finaly, how long do they think they can get away with putting Surefire labeling on these? Kind of makes the coincidental resemblance argument a little tough to swallow....
  #5
Old 01-30-2007, 01:45 PM
9volt's Avatar
9volt 9volt is offline
NIce review! I've been waiting for more info on this light. Do you feel it's worth the $25 or whatever they are charging for it?
__________________
  #6
Old 01-30-2007, 01:46 PM
9volt's Avatar
Quote:
I agree with the OP, please take it to another thread.
__________________
  #7
Old 01-30-2007, 01:56 PM
tenfour's Avatar
dammitjim: I need to use it a bit more. To me, the biggest functional drawback to the light is that the tailcap sucks. I assume I can fix that easily. Secondly, I don't know what the runtime on it looks like.
There are a lot of "pro"s about this light though - for $20, you get a 18650 compatible light with good beam, 2 levels, water resistant...
at the moment i'm happy i got it. time will tell the rest of the story.
  #8
Old 01-30-2007, 02:09 PM
tenfour's Avatar
OK I have made a lot of revisions to the review. Most notably I found that the light is NOT water resistant. I just need to seal up the tail and it should be OK though.
  #9
Old 01-30-2007, 02:15 PM
stonehold's Avatar
stonehold stonehold is offline
Thanks for the info. I'm in a biusness which lives or dies by intellectual property, so the question of legitimacy is of course relevant to me. As a newbie I was not aware of the light cloning going on and may have gotten one if not for your post. My enlightenment continues.
__________________
Zero search clutter.
  #10
Old 01-30-2007, 02:45 PM
270winchester 270winchester is offline
by this type of lights you mean blatant rip-off of a legitimate product designed to scam people? dang it they better cause controversy!! I don't care if I get ban for saying this, but people like you should be ashamed of yourselves.
there I said it. CPF has seen its lowest day since I joined two and half years ago.
__________________
"a government and its agents are under no general duty to provide public services, such as police protection, to any particular individual citizen." -Warren vs District of Columbia, after three women were raped, beaten for 14 hours and police never came after numerous 911 calls were placed
  #11
Old 01-30-2007, 03:12 PM
adirondackdestroyer's Avatar
adirondackdestroyer adirondackdestroyer is offline
Looks like this good be a good host for a Cree mod, which would make this one hell of a light. Maybe your model was a dud as far as the tailcap goes. Looks like a pretty damn good deal for under $30 shipped.
  #12
Old 01-30-2007, 03:26 PM
mchlwise's Avatar
mchlwise mchlwise is offline
You're sure on one today.
Thanks Tenfour for the objective and informative review.
  #13
Old 01-30-2007, 03:38 PM
kabkbak7321's Avatar
kabkbak7321 kabkbak7321 is offline
Quote:
I have recieved the same light,The tailcap is verry finicky.
overall a good light for the price.
Make sure you use surefire cells in it!
  #14
Old 01-30-2007, 03:41 PM
tenfour's Avatar
Why?
  #15
Old 01-30-2007, 03:43 PM
Just poking fun.When I got mine Surefire cells were all I had to put in it.
  #16
Old 01-30-2007, 03:47 PM
aurich_ aurich_ is offline
some should notify surefire about this, maybe they could inform us customs and do something about it.
there should be better ways to obtain a cheap housing for your mods.....
h
and i cant believe there are lengthy discussions in this forum about posting the 07 surefire catalogue based on copyright concerns and then people over here are promoting the sale of this light.
in germany havng such a light would be a fellony/misdemeanor
p.s.: sent an email to surefire, maybe they can do something about it
  #17
Old 01-30-2007, 04:41 PM
jch79's Avatar
jch79 jch79 is offline
**Do Not Feed The Vegan**
Deleted.
  #18
Old 01-30-2007, 04:51 PM
McGizmo's Avatar
McGizmo McGizmo is offline
As you wish but I would like to point out that intrinsic in this piece of shit forgery is a utter disregard for morals or ethics so it makes sense that any review would also be devoid of such.
As always, one's vote with their dollars is heard and counted. Perhaps a group buy could be initiatied for someone to rip off a real Sure Fire dealer* of real SureFire goods and we could have a technical discussion on them after we bought them. You know, compare tints and such. Again, we could leave the morals and ethics out.
* I am in no way proposing this because the CPF has rules about suggesting anything known to be illegal. This was suggested in jest as well as utter disgust!
__________________
Build Prices .... some mods and builds (not 4 sale) ..In darkness, who better to lead the blind than the blind themselves?
  #19
Old 01-30-2007, 05:08 PM
tenfour's Avatar
Hmm. I had no idea I was going to turn into a badguy from this :/
For what it's worth, I am not devoid of morals. as stated, i was hoping for the sake of information & truth that we could leave judgements elsewhere, and leave facts in here.
I need to clarify some things here in my own defense.
1) I am not promoting the sale of this light. I bought it mostly with the intention of making this review. I was amazed when I received it that it had SF branding. At that point should I have said "ok shady dealings are involved, no review?" I don't think so. I said "well, the light works. And people are curious about it. Emotions aside, I will detail the functionality for those are curious."
2) I purposely wished to keep comments about the morality of this light separate from discussion of the technical details for what I hope are obvious reasons. I do have opinions on the morality of products like this. I think it's discipable (sp?).
Please do not pass judgement onto me.
  #20
Old 01-30-2007, 05:09 PM
greenLED's Avatar
greenLED greenLED is offline
Quote:
Waaaay ahead of you, aurich. I sent them an e-mail when the first glimpses of this light went public. AFAIK, the info was passed onto their legal department.
I said it on the other thread about this light:
Quote:
Stick to your ethics. Vote with your wallet.
Personally, I'm at the whole thing.
  #21
Old 01-30-2007, 05:35 PM
mchlwise's Avatar
Personally, I think you're doing a great service by posting this review, and I applaud you for doing such.
(I'll justify my position, lest the mob mentality accuse me of "supporting" this light's sale and call for my permanent ban )
I feel this way for a few reasons:
1) you have clearly shown through pictures and text the differences between the knock-off and the authentic Surefire.
In the future, this will allow people who don't know any better to compare the light they got and know if it's authentic or a knock-off.
2) you have shown the lights performance, allowing people to make an informed decision.
Without your review, people would not have as much information. People may now buy the light because of that information, or they may decide to pass on the light when they would have otherwise bought it out of curiosity.
3) information is never a bad thing, and I believe in freedom to make informed decisions.
There are plenty of people around here who would advocate completely ignoring this light in the hopes it will go away. Others want people to know about it so they will go out and lynch those who made it.
I believe that people should be allowed to make their own informed choices, and that the more information they have, the better they will be able to choose.
By providing information, you have helped, not hurt.
  #22
good job greenled, too quick for me..
just thought i had to do sth about it...
@mchlwise: i agree that tenfour did an excellent job (in showing how bad the clone is), but comments from some people promoting the sale of the light is another thing altogether
  #23
Old 01-30-2007, 05:37 PM
PlayboyJoeShmoe's Avatar
PlayboyJoeShmoe PlayboyJoeShmoe is offline
*Flashaholic*
As a review it is just peachy. It tells us a lot about how the light works.
I can not BELIEVE that it is marked exactly like a Surefire. The possibilites, ALL BAD! make my head hurt!
I can't afford the real thing. But I'd NEVER buy a CARBON COPY CLONE of it!
__________________
http://img32.imageshack.us/img32/2640/usflaghalfmastmdwht.gif
PBJS
  #24
Old 01-30-2007, 05:40 PM
Mike M Mike M is offline
I've been out of town for the last couple days so I haven't been able to post. I recieved my U2 clone Friday. Packaging, etc was the same, even the serial number (A02621). I spent less than 30 bucks for this light because I was looking for a less than 30 buck light. I own 4 other SF's and have my share of modded Mags. I buy my stuff from "the little guy" and don't usually buy what I consider to be high dollar stuff from places like eBay, the money stays in town if it is available.
Anyways, I have several LED lights (No real U2's sorry) and this light packs a punch. I guess I am impressed with the output. I have had a few days to mess with it and it works well. the switch is clunky but seems to have no alignment issues. It is very hard to push and looks unsealed as stated above. The body has a large ID. 2 SF batteries "rattle" kind of like a M@G but I can't complain.
All in all, worth my 30 bucks and 2 weeks waiting.
FWIW I had no idea that light would be as much of a clone as it is. I was intoduced to DX and this light here under a title U2 copy now available, I guess the title was very correct.
  #25
Old 01-30-2007, 06:52 PM
AndyTiedye's Avatar
AndyTiedye AndyTiedye is offline
Don't dis tenfour for doing the review! If he had not done it we would not have
known that it was a counterfeit, rather than merely a clone.
It also doesn't seem to be all that great a light anyway.
There are plenty of other cheap Chinese lights out there,
including some that already have Cree XR-E LEDs.
Obviously, a counterfeit Surefire is likely to be confiscated by Customs,
making it a dubious bargain even if you don't care about the ethics of it.
  #26
Old 01-30-2007, 07:29 PM
Brighteyez Brighteyez is offline
My guess is that they're sending it through the mail and the Customs people that are assigned to the Postal Service facilities are just passing them through as a Passed Free item given their low value, and not knowing what is actually in the envelopes (often heat sealed plastic envelopes.) My guess is that a complaint to either Customs or the Postal Inspection Service with one of those envelopes would probably put the items on a watch list.
If an entire shipment were to come through conventional commercial channels, it would most likely be confiscated as you mentioned since many Customs enforcement personnel would indeed know what a real Surefire product looked like.
  #27
Old 01-30-2007, 07:45 PM
Exactly. I can't afford a U2 myself either. THat's why I don't have one.
__________________
  #28
Old 01-30-2007, 08:31 PM
fishx65 fishx65 is offline
Great review!!
Last edited by fishx65; 01-30-2007 at 08:48 PM. Reason: Because Justmyluck is 100% right!!!!
  #29
Old 01-30-2007, 08:32 PM
justmyluck justmyluck is offline
Kudos to tenfour for posting this review. I echo what someone said above in that information in and of itself is a good thing. He took a chance on this flashlight, and is simply giving a review of what he found (and rather objectively I might add).
What I would say bothers me slightly is the reaction this thread has gotten, and in such, I feel sorry for tenfour having to bear this. I see this as a case of common courtesy. Tenfour prefaced his review asking for the debate of ethical/moral issues to be taken elsewhere. Hey, we all know this was going to be a copy of some sort from the sales pictures. This has been well discussed/argued elsewhere (a LOT). But yet some users felt the need to come here into tenfour's thread and still bring up the very issues he asked to have taken elsewhere. Frankly, I find that to be nothing less than rude.
It would have taken all of 2 minutes to start a new thread to discuss ONLY the moral/ethical/copyright implications of this particular light, as opposed to the performance which was supposed to be discussed here.
I may be a relative newcomer here at CPF...I love the fact that an amazing amount of data and opinions are available here for review...but I do feel that this blantant disregard for the requests of original posters is far too out of line and should be dealt with.
My 2 cents...thanks for reading.
Eric
  #30
Old 01-30-2007, 09:22 PM
daveman daveman is offline
A clone would be fine.
A counterfeit is not.
This is flat out forgery.
Well done on the review though.
  #31
Old 01-30-2007, 09:54 PM
rookie rookie is offline
Thanx for the great review and detailed pics!
  #32
Old 01-30-2007, 09:57 PM
McGizmo's Avatar
tenfour,
I feel I owe you an apology. I falsly assumed that you purchased this light knowing it was labeled as a SureFire U2. To me, such a purchase, regardless of intent would be considered dubious. Your request to keep the ethics out of this thread seemed like asking too much and especially in light of some of the follow up comments where not only was the morals or ethics ignored by the poster, questions were raised as if there was no issue what so ever.
Anyway, your review is sound and well stated. If this light is brought to market without obvious misreprentation as a forgery, it may have a legitimate place.
The light has not hurt SureFire here on CPF as any news can be good news for the marketing people. Beyond CPF any forgery has negative effect on all but those exploiting the ignorant or unknowing.
Well, I got long winded and didn't plan to. I see you as an innocent and honest messenger here and I don't hold the message itself against you but thank you for bringing it out.
__________________
  #33
Old 01-30-2007, 10:29 PM
The_LED_Museum's Avatar
The_LED_Museum The_LED_Museum is offline
*Flashaholic*
I just purchased one ***SOLELY*** for evaluation on my website; PK at SureFire will definitely be furnished with the URL when the web page is published.
__________________
  #34
Old 01-30-2007, 11:03 PM
AndyTiedye's Avatar
Quote:
Exactly! And does it not seem extremely likely that such a complaint will
be forthcoming from Surefire? And how would Customs respond? Wouldn't
they start opening up everything that comes in from Dealextreme? Most of
what they sell is on the up-and-up, like their newly-released Cree lights,
which many of us (including me) have on order, but we may still be a long
time getting it now.
Anybody want to post on dealextreme's bboard about it?
FWIW, kaidomain sells a lot of the same stuff, but no faux Surefires.
  #35
Old 01-31-2007, 04:21 AM
M I K M I K is offline
I agree 100%. God bless the USA, CPF and the real SF.
  #36
Old 01-31-2007, 05:52 AM
abvidledUK's Avatar
abvidledUK abvidledUK is offline
Don't apologise.
The excellent review is most welcome and allows buying decisions to be made on the technical merits.
It's sold as Surefire U2 Style K2 Flashlight Black
It's not marketed as Surefire U2 K2 Flashlight Black
The photo's don't purport to claim it is a Surefire U2 Style K2 Flashlight Black
We all know it's probably lower quality (maybe not)
There are so many posts berating SF and SF CS, is it any wonder a copy is introduced.
It may have the SF logo on it, but that is not discovered until receipt.
So, having purchased the Surefire U2 Style K2 Flashlight Black, and discovering it is only a Surefire U2 Style K2 Flashlight Black, and not a real SF torch, you can return it, all costs covered.
I think a lot of the fuss is because SF claim that their torches are all made in the USA.
"Where was my flashlight made?
In the U.S.A. SureFire is proud of the fact that it has not joined the outsourcing trend, and maintains manufacturing, assembly and test facilities in Southern California."
If they were made in China, ala Fenix, and distributed in USA, would there be all this fuss.
CPF'ers seem quite content to buy, keep and recommend Fenix clones, albeit, w/o Fenix logo.
No doubt, if there is commercial dubiousness going on, then the manufacturers of the Surefire U2 Style K2 Flashlight Black will be asked to remove from sale, followed by court action.
However, the fact that the manufacturers (and the dealer) are based in Asia may negate this somewhat.
I do not condone, nor do I object to the Surefire U2 Style K2 Flashlight Black.
Just my 99p's worth.
Nice review.
I won't be buying one, based on technical merits alone.
__________________
Batteries, batteries, I need more batteries ........
  #37
Old 01-31-2007, 06:07 AM
PEU's Avatar
PEU PEU is offline
I also was expecting to see a review, thanks 10-4 for doing it.
What I don't understand is why the dealer choosed to forge a brand and the shape, I can't think of any good intention if you go that way, no matter how you call it or the wording you use to sell the stuff, its plain wrong.
A shame, because the light at $20~$26 shipped is not a bad deal at all...
Pablo
__________________
Homepage in progress: http://www.neoca.com.ar
  #38
Old 01-31-2007, 08:59 AM
tenfour's Avatar
Thanks for the kind words
Another update regarding the tailcap - it comes apart in these pieces (in order):
boot
shim (circular plastic piece with raised circle in the center)
housing (big plastic thing that keeps the switch in place)
switch
threaded conductive washer
brass contact
plastic cover
Using J-B Weld, I glued:
- the shim to the boot, and
- the housing to the switch
...all as centered as i could get using my eyes. Let cure, reinstall, and the switch is just fine now.
Unfortunately, I tightened the lid on my JB Weld too much though, and it got a small crack out of which compound spilled all over my desk. Oh well!
My final plan is to remove the surefire branding, so i don't get a sick feeling every time I use this light.
__________________
  #39
Old 01-31-2007, 09:32 AM
Atomic6 Atomic6 is offline
Interesting Review on several levels. Illegal booty for sure. Hard to place ethics aside on black market goods and brand names. I think I'd rather have one good light ($$ Surefire) than buy 2-4 crappy clones and end up spending the same amount eventually when it is all said and done. Easy to say-hard to do. Tempting to throw down $29.00 at-a-time. Very hard to plunk-down $200.00.
__________________
  #40
Old 01-31-2007, 09:53 AM
paulr paulr is offline
Tenfour I've been wondering how one might remove that Surefire branding. Grinding off the ano finish doesn't sound too nice. I guess you could paint over it with black enamel nail polish or something like that.
  #41
Old 01-31-2007, 10:07 AM
BentHeadTX BentHeadTX is offline
Very good review/warning at the same time
The light would fit perfectly with my Rolax watch, Benchmaid knife and Leathermen multi-tool.
The bad thing about the counterfit is the unsuspecting consumer that buys one on Ebay. They might send it in to Surefire with complaints about the quality or start bashing them online.
It must of been shocking to open up a "Surefire U2 style" light and find out it has Surefire logos on the barrel. Shame, they should of left the non-functional Surefire bling off the light and built just the light.
__________________
Peak Pacific AAA UP brass (EDC) E01 (keys), Peaks, Arcs, Fenix, Q5 Aspheric HA-III Mag etc.
  #42
Old 01-31-2007, 10:10 AM
Brum's Avatar
Brum Brum is offline
Quote:
I believe kitchen sink deplugger/oven cleaner (correct translation?) can be used to dissolve the ano coating. A bit of sanding, a few hours of dremeling with a polishthingy attached and you have a very shiny light. You can get it to be a complete mirror (patience....), but then you couldnt hold it anymore due to fingerprints. I find sanded light (1200grid) to look very nicely. You could also have it sandblasted and clearcoated afterwards, that also looks very good.
  #43
Old 01-31-2007, 10:35 AM
Pax et Lux Pax et Lux is offline
I read the review with interest (and horror) - a good piece of journalism.
I am pleased someone actually took the time to show what this light is all about, and compare the fake to the real thing. . . and I think more people would have applauded your hard work had it not been for that one word, "mush."
Being honest, I feel a bit uneasy, because I use a $1 Photon clone - does this make my a hipocrite?
__________________
"Do not go gentle into that good night,
Rage, rage against the dying of the light."
  #44
Old 01-31-2007, 11:11 AM
cutlerylover's Avatar
cutlerylover cutlerylover is offline
Sorry double post...I have got to learn to be patient and just let the page load before clickign again, lol...
__________________
- JEFF
  #45
Old 01-31-2007, 11:14 AM
Listen it stinks that there are counterfeits out there like this, mainly in my opinion because someone who migth not know anythgin abotu lights can buy one and the quality reflects surefire because it has that anme on it...to a noob this may put off that person to surefire products, which stinks...but on the other hand most of us CPF members know the difference and can shoose not to purchase these counterfeit lights...My biggest concern will be when these are put on ebay under surefire, and when they pop up here on the forums in the sale thread...I wouldn't want a new member to say wow what a price on that surefire and buy them and be dissapointed...
Now I have been a fan and collector of Zippo lighters for years, and they have hundreds of COUNTERFEIT ligthters to compete with, I mean the same right down to the markings on the bottom, and even the insert! Not collectors know what to look for to make sure the lighters in question are real or not but again people new to collecting do not and they get fooled over and over again...Infact Zippo has a crack staff of over a dozen lawyers who are constanlty lookign for these dealer who sell them and pursuing legal action...but for the most part they can never touch the makers...they do 2 things to help...They sometimes hit the jackpot with customs, once seizing over 2,000 counterfeits in one shipment! And the other thing they do is contact dealer and sellers of these fakes...Sometiems On ebay if they are repeat offenders...Sellign one or 2 might be a mistake and you migth not know what your selling, but people who sell hundreds one bay, they are the ones really getting into trouble! And onlien stores who sell them and get caught are sued as well...I belong to Zippoclick the Zippo collectors club, and there is a section on their forum that is just meant to post where you spot fakes, and they have Zippo staff monitoring that section of the forum 24/7...
What I think might happen is that fifthunit/dealextreme will go out of buisness if Surefire see that they are selling these...even though they might not make them...
I see counterfeits in every one of my hobbies...Knives, Zippos, and now flashlights...I don't collect Watches but we all know about watch counterfeits (rolex, Omega, etc...) Pretty much anythign nice has cheap copies and counterfeits...
But don't get em wrong, a copy, or clone is one thing but to actually use logos and name brands is a whole different ball game...Clones can slip through the cracks since sometimes they change the design just a bit, but there is no reason to use another companies name, thats just asking for it...
p.s. I too use photon clones...it doesn't say photon on it, but if it did would I not buy them anymore...? Maybe im a bad guy too...?
__________________
- JEFF
  #46
Old 01-31-2007, 11:16 AM
josean's Avatar
josean josean is offline
I joined this forum because I am interested in quality flashlights. I have already about 20 chinese unknow brand poor quality led flashlights, and I am not interested anymore in such kind of products.
I have nothing against chinese products (in fact I am very happy with several Fenixes I owe, and even I have given several more as gifts), but I do not want crappy products (direct driven leds, decorative o-rings which do not seal the tube, clickies which get broken after several days of use, and so on).
I will take this post just as informative, as a kind of "be careful when you buy your next flashlight and do not buy a fake product".
__________________
LED addict
  #47
Old 01-31-2007, 11:20 AM
If nothgin else this just shows us what to look for and what not to buy...If your against this light, which many of you are, than this thread gives you information that migth be helpfull as to not buy this by mistake from someone...So I certainly appreciate this thread and review, and I thank Tenfour for posting it!
__________________
- JEFF
  #48
Old 01-31-2007, 11:48 AM
iced_theater's Avatar
iced_theater iced_theater is offline
I was wondering how that light would compare, but since it seems it's just like your average Chinese light, it's most likely not worth it to buy.
  #49
Old 01-31-2007, 11:52 AM
tenfour's Avatar
iced_theater: yea if anyone's dying for a cheapy chinese light, you'll be much better off going with the cheapy "DX 3W Cree" light on the same site. For many reasons =)
  #50
Old 01-31-2007, 03:12 PM
KROMATICS's Avatar
Quote:
No, the fuss is because they not only copied Surefire's design but also used their logo, product name and website address on the product. That's just plain wrone and illegal in most countries. I think most people understand and appreciate that.
The light could have stood on it's own merits had they used their own design and marketing. That just makes this situation even more ridiculous.
__________________
KROMA
TICS
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
