CandlePowerForums VISITOR MESSAGES
ARE NOT PRIVATE!!
Read more...
Go Back   CandlePowerForums > Custom & Modified Flashlights > Homemade and Modified Flashlights
CPF Only
User Name
Password
Register
4Sevens
Reply
Thread Tools Display Modes
  #1
Old 07-27-2003, 11:04 PM
hotbeam's Avatar
hotbeam hotbeam is offline
Default Premium Hotlips-C heatsinks...
Please see the original Premium Hotlips thread for availability details.
  #2
Old 07-27-2003, 11:27 PM
Rothrandir's Avatar
Rothrandir Rothrandir is offline
*Flashaholic*
Default Re: Hotlips-C Heatsink Preorder/Expression of Interest
just can't leave well enough alone can you? [img]/ubbthreads/images/graemlins/twak.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
  #3
Old 07-28-2003, 07:11 AM
StoneDog's Avatar
StoneDog StoneDog is offline
Does anyone know the ID of a Mag "C"?
Jon
  #4
Old 07-28-2003, 07:52 AM
hotbeam's Avatar
StoneDog
The ID averages out to 28mm (***EDIT: Correction. ID ~26.3mm. Old one was 28mm)
  #5
Old 07-28-2003, 10:31 AM
Overamp Overamp is offline
I would take 3.
  #6
Old 07-28-2003, 11:25 AM
BentHeadTX BentHeadTX is offline
Hotbeam,
Will those fit in a Brinkmann Nexstar 2C?
  #7
Old 07-28-2003, 12:28 PM
Y2Kirk1028's Avatar
Y2Kirk1028 Y2Kirk1028 is offline
[ QUOTE ]
hotbeam said:
StoneDog
[/ QUOTE ]
The newer mags have an ID diameter of ~26.3mm. These are the ones with the "C" in front of the serial #, and has the "maghead" insignia on the swith boot. Also the switch assembly slides out from the bottom and doesn't have the retaining ring.
I say forget about mags..how bout a coleman ?
  #8
Old 07-28-2003, 12:39 PM
ledlurker ledlurker is offline
I will take (2) of the C size ones and (1) of the D sizes
  #9
Old 07-28-2003, 01:12 PM
lildave lildave is offline
I'll take 2
  #10
Old 07-28-2003, 04:57 PM
snakebite's Avatar
snakebite snakebite is offline
i will take 2 c and 3 d
i can paypal when ready and you can hold the 3 d units till the c are ready.
  #11
Old 07-28-2003, 05:28 PM
hotbeam's Avatar
[ QUOTE ]
[/ QUOTE ]
Hmmm Y2Kirk1028
26.3mm (!!). That is small. I'll check again with my Cs.
Brinkmann Nexstar 2C? That's an option... how many people has that?
Coleman is also an option... again, what is the usage on that?
  #12
Old 07-28-2003, 06:34 PM
Kill-O-Zap Kill-O-Zap is offline
hotlips:
I guess you took my advice in the other thread to heart and decided to make the diameter 28 for a nice tight fit (REAL tight) in a 26.3 [img]/ubbthreads/images/graemlins/grin.gif[/img]
Seriously, though, is the fit intended to be tight enough that it will stay in w/o epoxy?
Either way, I'm registering my interest for at least two.
Thanks.
  #13
Old 07-28-2003, 07:51 PM
hotbeam's Avatar
Very funny Killo... I will need to reconfirm the ID again later.
  #14
Old 07-29-2003, 09:06 AM
hotbeam's Avatar
Please check your IDs of your flashlight bodies. The old ones are 28mm ID and new ones (with the Cat imprint on the switch, "C" in front of the serial number and no o-ring inside the head) have an ID of ~26.3. The run I will be doing will be for the new ones, ie the Hotlips-C OD that fits inside the mouth will be ~26.3mm.
  #15
Old 07-29-2003, 09:16 AM
StoneDog's Avatar
Well, I'm out then - plesae disregard my PM. I was hoping it would fit my older style Mag "C".
I will send a PayPal for one or two "D's" tonight.
Jon
  #16
Old 07-29-2003, 09:39 AM
snakebite's Avatar
me too
dammed if i will buy another m@g product to use em.
i have an old 3c that could use a 1w dd.
ever thought about a sleeve as an adapter?maybe tight enough to do a shrink fit to install
as in heat the od and freeze the id?
[ QUOTE ]
Jon
[/ QUOTE ]
  #17
Old 07-29-2003, 12:50 PM
Y2Kirk1028's Avatar
[ QUOTE ]
[/ QUOTE ]
Why not offer both sizes?
  #18
Old 07-29-2003, 05:21 PM
Rothrandir's Avatar
*Flashaholic*
offering both sizes would mean a greatly increased manufacturing cost [img]/ubbthreads/images/graemlins/frown.gif[/img]
  #19
Old 07-29-2003, 06:25 PM
hotbeam's Avatar
StoneDog: PM sent.
Snakebite: Excellent idea. [img]/ubbthreads/images/graemlins/thumbsup.gif[/img] How about the Hotlips-C have the 26.3mm diam. The sleeve (hollow cylinder) have an ID of 26.3 but OD of 28.1mm. To use, epoxy the two together for a larger ID OAC or use the Hotlips-C as is for a newer OAC? Again this is a numbers game. How many sleeves to make? From the numbers above, it looks like this whole project (Hotlips-C) is unlikely to get off the ground. I'll wait till the 8th and evaluate then [img]/ubbthreads/images/graemlins/frown.gif[/img]
Y2Kirk1028: The sleeve idea will solve the 2 size issue.
Roth: Very true.
  #20
Old 07-29-2003, 10:18 PM
jcciv jcciv is offline
I am interested in 2 of the c size. I bought a 2c cell Mag light 2 days ago at Home Depot in Houston, TX, and the inner diameter at the top of the light is 28.13cm. The serial number is 24839490.
  #21
Old 07-30-2003, 11:07 AM
gbreckley gbreckley is offline
I am definately in for at least 5 maybe as many as 15.
Greg
The D ones are awesome by the way
EDIT: All of them the new smaller diameter 26.3
  #22
Old 07-30-2003, 12:41 PM
Elnath's Avatar
Elnath Elnath is offline
Like my D model alot. I'd be in for 2 of the C size. (looks like I'd need one sleeve--for an older larger unit, and one of the 26mm)
  #23
Old 07-30-2003, 03:00 PM
MenaceSQL's Avatar
MenaceSQL MenaceSQL is offline
I'm in for two of the C's. [img]/ubbthreads/images/graemlins/popcorn.gif[/img]
26mm for me purdee pleeze.
  #24
Old 07-30-2003, 06:29 PM
hotbeam's Avatar
Thanks for the interest so far. If you have pre-ordered, please edit your post and indicate what diameter your OAC is... so I can determine if a sleeve is needed. It is either 28mm or 26.3mm.
Any other sizes coming from Ontario? [img]/ubbthreads/images/graemlins/icon23.gif[/img] Get it right!!! [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/mad.gif[/img]
  #25
Old 07-30-2003, 07:15 PM
finboy1672 finboy1672 is offline
I'd like two C's and one D if available.
  #26
Old 07-31-2003, 10:08 AM
By Preorder, do you mean that we should pay now? How much each? How do we pay?
Thanks,
John
  #27
Old 07-31-2003, 06:30 PM
hotbeam's Avatar
John, no need to pay. The project may not get off the ground due to numbers. Please just edit your post and tell me whether you want the Hotlips-C and/or Hotlips-C with Sleeve. This will tell me how many Sleeves I need to get made (if at all)
For everyone:
Old C bodies have an ID of 28mm. Serial number does not start with "C" and no insignia on the switch button.
New C bodies have an ID of 26.2mm. Serial number starts with "C" and has the insignia on the switch button.
  #28
Old 08-01-2003, 12:08 PM
done, thanks. I have a 28mm body, even though I just bought the light.
  #29
Old 08-02-2003, 10:26 AM
frogmonk's Avatar
frogmonk frogmonk is offline
I'm interested in two (2). Thanks!
  #30
Old 08-06-2003, 08:43 AM
hotbeam's Avatar
Two (2) more days to go and I will then evaluate where to go from here.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
