They are LiFePO4 32700 with threaded posts on both negative & positive side. I've seen these in larger cells, but not 32700's. Pack currently shows 2.15V. I want to disassemble the pack and check / charge the batteries individually, and possibly use them in my Maglite with 3D - 6D Malkoff Drop in LED. I'm guessing that one or two of the cells is bad & I would hopefully have 2 good cells for powering the Malkoff LED.
It came out of 1 of 2 solar street lights I purchased about 3 years ago and is supposed to be a 55Ah pack. Of course they also call the light "10,000 lumens" but my Convoy L6 on high (not turbo) is brighter..... This light stated having problems about a year ago, not as bright, doesn't run all night, though as they days are getting longer, it was starting to get a little brighter, & run a little longer. I was using it as a security light to be able to see the front of my shop clearly at night from inside my house. So I bought a much cheaper & brighter light for temporary use till I can afford a real solar parking/street light...
