HKJ
[SIZE=+3]LiIon 18650 battery comparison[/SIZE]
I have made a new battery test: 18650 battery test 2011, it is also on cpf
A 2012 test can be found here
The name 18650 means that the battery has a diameter of 18mm and is 65mm long, but when a protection circuit is added the battery will be a few mm longer. How much longer will depend on the actual protection circuit and how it is mounted.
These graphs show the size of the batteries. The length is from top of battery to bottom of battery, measured on the most protruding parts. With the diameter I have tried finding the largest diameter (The batteries are not completly circular).
Some of the batteries are flat top, what this means is explained here: Battery, button or flat top
For more information about how a protected battery is build see The Anatomy of a Protected Battery.
This graph shows the measured capacity for each battery with different loads. One thing to note is that many manufactures overstates their capacity.
Note: I have used multiple batteries from each manufacturer and multiple chargers, i.e. the different runs for the same type battery might not be directly comparable (As in same battery and exactly same charge condition).
Note: TrustFire TR2400 (gray) is very variable in capacity.
On the graph, the black trace is 0.3A, red is 1A and green is 3A discharge current.
[SIZE=+2]AW 2200 (Black)[/SIZE]
This battery has protection.
Size: diameter: 18.4mm, length: 67.4mm
The minus pole has a metal protection.
Source: AW, Sep 2009
[SIZE=+2]AW 2600 (Black)[/SIZE]
This battery is a flat top battery and will only work in equipment with a raised plus pole. Two batteries placed in series will connect (Not all flat tops will do this).
Size: diameter: 18.6mm, length: 67.7mm
Source: AW, Nov 2009
[SIZE=+2]AW IMR1600 (Red)[/SIZE]
This battery uses IMR (LiMn) chemistry and does not have or need a protection circuit.
Size: diameter: 18.3mm, length: 65mm
Source: AW, 2009
[SIZE=+2]SolarForce 2400 (White)[/SIZE]
Size: diameter: 18.7mm (Mostly 18.4, but it has a bump), length: 68.3mm
Source: SBFL, Feb 2010
[SIZE=+2]Soshine 2800 (Black)[/SIZE]
Size: diameter: 18.4mm, length: 68.8mm
The minus pole is the copper on the protection pcb.
Source: DX:28678, Jan 2010
[SIZE=+2]Tenergy 2600 (Cyan)[/SIZE]
Size: diameter: 18.4mm, length: 66.7mm
Source: BJ, Jan 2010
[SIZE=+2]TrustFire TF2400 (black/red)[/SIZE]
Size: diameter: 18.3mm, length: 68mm
Source: DX:20392, Jan 2010
[SIZE=+2]TrustFire TR2400 (Gray)[/SIZE]
This battery is either one of the good or one of the worst batteries, depending on how lucky you are. The blue trace is a 1 amp trace of a bad battery.
Size: diameter: 18.5mm, length: 67.6mm
Source: DX:5776, Jan 2010
[SIZE=+2]TrustFire TR2500 (Blue)[/SIZE]
Size: diameter: 18.6mm, length: 68.9mm
Source: DX:5790, Dec 2009
[SIZE=+2]UltraFire BRC3000 (gray/red)[/SIZE]
Size: diameter: 18.6mm, length: 68.0mm
Source: DX:21474, mar 2010
[SIZE=+2]UltraFire LC2400 (Gray)[/SIZE]
Size: diameter: 18.5mm, length: 68.9mm
Source: DX:19624, Jan 2010
[SIZE=+2]UltraFire XSL2600 (Red)[/SIZE]
Size: diameter: 18.6mm, length: 69.1mm
Source: DX:28677, Dec 2009
[SIZE=+2]UniqueFire LC2400 (Blue)[/SIZE]
Size: diameter: 18.5mm, length: 68.8mm
Source: DX:29031, Dec 2009
[SIZE=+2]Xtar 2200 (Blue/green)[/SIZE]
Note: These batteries are named 18700, not 18650.
Size: diameter: 18.5mm, length: 69.5mm
Source: Xtar, Dec 2009
[SIZE=+3]Notes[/SIZE]
Source:
DX: Dealextreme
BJ: BatteryJunction
AW: AW on cpf
SBFL: SBFlashlights
Source: AW, 2009
Source:
DX: Dealextreme
BJ: BatteryJunction
AW: AW on cpf
SBFL: SBFlashlights
