gunnertwo
Ok, might be a dumb question. These batteries (pictured) rate at 100% by my tester. They will not run my S/F flashlights. Why?
G2
G2
That's OK, and I know very little about SFs too;-) Is yours LED or incandescent bulb, and did it come set up for 2 x CR123A cells, and if so will it still work with CR123A primary cells?Well, obviously I'm a noob
Roger that, but my question was whether the light(s) that are intended to use 2 x 123 cells still work w/ 2 x CR123 cells AFTER having had the cells in your OP tried in them (and having them fail to work). That's critical to the rest of the explanation I can possibly offer.still work
I have no SFs and thus am not the best to say, but I believe the link below is what SF recommends for your application. Note under 'read more' that (the way I read it) they are recommended for LED lights, but should not be used in incandescent lights. These are LFP (LiFePO4) lithium ion cells, with a characteristic voltage of just over 3 volts in operation, vs the 3.7-4.2V of the cells in your first post. Especially given there's 2 in series, that overvoltage could destroy lights not designed specifically to use them.Now I'm tracking, had CR123 in both lights before. Installed the recharge, no workie, replaced with CR123, worked normal. Thanks.
G2
