16340 recommendation?
mckeand13
USA
I'm in need to some additional cells for my HDS rotary. It's an EDC and my cells are getting a bit tired.
Now that AW is no longer, what is the "go-to" cell for QUALITY protected 16340's?
I don't need, nor do I care for, USB charging on the cell itself so hard pass on those.
Thanks.
aznsx
Phoenix, AZ USA
I see Nitecore has a 950mah cell. Is that capacity real?
See the last 2 sets of numbers in this post for NL169. The answer is that depending on discharge voltage cutoff setting used (I used 2.8V - not 2.5V, as some manufacturers spec) and discharge current used (I used 1.0 & .5A in this test), the best answer is likely: 'yes, there or thereabouts'. If tested w/ the Opus 3100 (which I did not do for the NL169), they'd likely measure above label rating. Close enough for me.
tech25
Near the Big Apple
My favorite one to use with my HDS was the Vapecell INR 16340.
I also used the efest and fenix 16340s without issues or noticeable differences.
