- Joined
- Jul 15, 2021
- Messages
- 41
Check the Aluminum LED Light Channels, which can be mounted on the drywall & plasterboard & sheetrock.
the standard length is 1M, other lengths are available from 1.5M, 2M, 2.5M, 3M and max 6M. can be cut to any length for your project and custom length are available. the LED Channels are made of 6063-T5 extruded aluminum material and with anodized surface treatment, with a single flange and can be recessed into the 12.5mm plasterboard on the ceiling or wall for indoor decoration projects. the inner width is 10.5mm and allows the max width of LED Strips is 10mm, recommend installing the COB LED Strips to create a seamless line of lighting. there is only one type of diffuser available, the PC diffused cover for the smooth light output.
Link: https://www.ledbe.com/recessed-light-fixture-housing-for-drywall-use
