Eiger clip
Vemice
Just ordered a Prometheus clip for my Eiger. Anything difficulties I should to know about?
Thanks.
jabe1
Cleveland,Oh
Not really an issue. Some lights need a modified momentary switch, mine was okay.
you just need to remove the o-ring to get the clip on the switch, then replace it before re-assembly.
I would post a pic, but you'll find the process straight forward enough.
with your SS Eiger, it will make a great edc light.
Vemice
Easier than I thought. Looks better too.
Thanks for the help.
Vemice
Is it normal that the light will not come to full power with the clip installed using the momentary switch?
Not sure that it did before but seemed to go pretty close.
edit; Figured it out. Apparently my Eiger doesn't like eneloops. Installed an Energizer lithium primary and it is fine.
