Malkoff M31W
thermal guy
ny
It needs 1.8 volts for full power. A L91 would get you there. I have used a regular 1.5 with mine and it's not far off from being full power. Till the voltage starts dropping
LEDphile
The M31LL from Illumn runs at full output from an L91, and looks pretty close to full output on a freshly charged NiMH (but is very close to dropping out of regulation. I suspect what you really want is an M31LLL (Illumn has a few) - 15 lumens OTF and should run just fine on any sub 3V AA battery.
ilikeguns40
Western PA
Thanks. I've had so many of the 219b drop ins from Illumn that I'd like something different lol. That may be the way to go though, just really wanted a low output SST20 3000k powered by a AA or CR123, it's a very nice led
May just get the M31W
ilikeguns40
Western PA
Ordered the M31W, can run on a CR123 primary or AA - fantastic
What you think the estimate runtime is on the L91?
thermal guy
ny
Boy I've never done a single L91 with that drop in. But you'll get a steady drop in output for hours
troutpool
Arizona
I've been running an M31LL 219B V3 on a single L91, and while I have not done accurate runtime tests, the runtime before output diminishes is quite good. This dropin is in a VME head on Malkoff's 1xAA body, a very useful setup.
ledbetter
California Central Coast
I run single Eneloop(1.2v) in M31w and output is similar to medium mode on Malkoff's 3mode li-ion MDC Neutral head, so I'm guessing around 50 lumens. Very useful beam, similar to M61LLLL. Can up lumens a bit with 1.5v aa and get full output with Olight's weird 2.4v 14500 battery which I also use in MDC AA light to boost moonlight mode to over 1 lumen.
ilikeguns40
Western PA
Great information. Thank you
