Paris suspends electric bus fleet after fires.
Hooked on Fenix
Usually don't see something like that except in the movies, if the bus drops below 55 mph. This looks like the sequel, No Speed.
idleprocess
decamped
From the Inside EVs article:
Bolloré's 12-meter (39-foot) long electric buses can transport up to 109 passengers and offers an estimated driving range of up to 320 kilometers (199 miles) from Lithium Metal Polymer (LMP) battery packs totaling 441 kWh of stored energy.
LiPo packs for transportation strike me as a bit novel. My image of LiPo is high power density to weight at the expense of energy density and the physical robustness of conventional li-ion.
I gather that RC events pretty routinely use cinder block + sandbag containment cells for recharging them, such is their tendency to vent energetically, however that might also be due to aggressive charging regimens.
turbodog
central time
Thats what Id like to know too.
If they ignite, flames travel upwards. On the roof... passengers can exit underneath the flames, being only broiled, like a whopper. Underneath the belly... flames engulf the bus, leaving a nice crust on the passengers/kebabs.
Probably better protected from vehicular impacts also.
idleprocess
decamped
Can't help but wonder if the choice of LiPo chemistry necessitated this design choice.
PhotonWrangler
In a handbasket
While it's probably much safer for passengers, it could set some trees on fire. It's amazing that it apparently didn't cause something else to catch fire.
xxo
Buses need to ride low to the ground to better accommodate people with disabilities - if they put the batteries underneath they would be vulnerable to road damage.
thermal guy
ny
Guess it's more appropriate to say when they ignite. but still all that molten aluminum and crap will rain down on them I would think.
turbodog
central time
If I were designing it, I would certainly see a tray capable of withstanding a reaction underneath the pack. That won't stop the spray ejected by the reaction itself, but it's a start.
Hooked on Fenix
If I were designing it, I'd locate the battery pack at the very back of the bus with a bimetallic type of passive ejection system like a circuit breaker or a thermoelectric fan for a wood burning stove. If the battery pack heated up too much and was going to explode, it would be pushed behind and away from the bus. It would suck for tailgaters, but the passengers would survive if the bus was moving.
jtr1962
Flushing, NY
If I were designing it, I'd just use LiFePO4 cells and avoid the vast majority of problems in the first place. Sure, fires can still start if the cells are shorted, but at least they won't go into thermal runaway.
