Can anyone tell me what kind of copper washer this is? It came with a Malkoff m61w drop in. Thanks
A person can find them through other sources than Torchlab at fraction of the price
Dan also asks a buck each for battery bumpers, orings that cost him .02 each. I guess you can argue logistics if that's all a person is ordering. Like you said, if a person is spending hundreds of dollars, Dan should send for free (like Gene does) but he doesn't.I was floored when I saw what they charged.
I can order them for $.08 each.
Or Malkoff will give them for free.
Thanks. You happen to know the exact size of them? Are overeadys the same size as malkoffs?They're also called wave washers. They come 3 or 4 waves for even better contact.
Haha what's funny is that I actually did that first with a piece of 14/2 wire and then I found this washer laying around my parts bagThe other day I flattened some 14 gauge solid copper wire and made my own. Took like 5 seconds and may have cost $.02
You really don't have to flatten it. I was just messing around that day…I've used it round many times
My p60vn was a bit too short in my VME setup and needed that washer to complete the ground connectionMalkoff uses his copper washers when fitting M61 to Z44 or repo heads..
OR, he's using 19 or 22mm that fits the bottom of his drop-in..
What's your application?
I like Kernels ingenuity.. Get yourself a piece of electrical ground copper wire (old florescent fixtures or Depot) wrap it around a pipe of appropriately size. Cut off the wire circle, then flatten copper in smooth jaw vice. Voi.la!
