The definitive Malkoff Hound Dog Super thread
etc
Northern Virginia
Say Hello to my little friend.
Looking at the head, it's the unmistakable profile of the Hound Dog Super. However it has taken a step further. This modification is what I will call Malkoff Hound Dog Super Plus version. The 18650 extension is bolted to it making it a 3x18650 monster light. The voltage is within specs or under 14V. Obviously do not stick 6 primaries in it. They will fit and result in a very bright and short runtime measured in nanoseconds. If you must run it on primaries, up to 4 of them, unbolt the extension or use the 18650 spacer.
The runtime and the lumens are somewhat increased with the Super Plus. The runtime is increased by about 50% from 1 hour to 1.5 hours IIRC. It's hefty and a very serious social device. Under any serious circumstances, HD Super Plus is the tool I would rather have over anything else, custom made or from a SOB (Some Other Brand).
Hound Dog Super Plus on High. Yes, it does shine like a car headlight, in fact brighter, more focused.
HD Super on Low. Even on low you can see it's a significant force.
Now let's contrast the above with the Malkoff Hound Dog 18650. The hotspot is less intense but the spill is considerably larger.
etc
Northern Virginia
More pics coming, I will try to find something with less light pollution.
Will also take some shots side-by-side.
You can see that the 18650 Hound Dog does not really compete with the Super Plus, they are much different devices.
In all honesty, for daily tasks, I much prefer the Hound Dog non-Super edition as it's more compact -- in my case anyway, since I extended my Super and the beam profile is a lot more useful. I added lumens and runtime at the expense of compactness. This thing is as huge as a 3D Maglite or bigger. I will take a family portrait one of these days.
The Hound Dog Super is indispensable outdoors. The Hound Dog is useful all around, indoors or outdoors, whereas the Super is marginally useful indoors if you are talking about 15 feet. It has a huge, very intense hotspot that's wasted inside. Indoors, I tune it down to the low mode. The other attribute is, at close ranges, you see rings. They disappear outdoors outside of about 20 feet. But this is not a WWH light.
To sum it up, the Hound Dog has an intense 29K lux hotspot and a huge spill, while the HD Super (Plus) has a much more intense, and even bigger hotspot that's about 79K lux but noticeably less flood/spill.
So the choice is not between Super or 'regular', get both.
tab665
north carolina
glad to see a dedicated hound dog super thread! I got mine last summer, it stays next to the front door at all times. I do hold onto the hope of an even larger variant in the future. something along the lines of a xhp35 HI with a dedicated 3 cell body
etc
Northern Virginia
I did not know what XHP32 was, turns out it is a Fenix.
to be perfectly honest, I am a not a fan of the 3x18650 side by side configuration, the light is short but huge and hard to grip. I much prefer the 2x18650 config occasionally modding it to run off 3x18650. Or 3x18650 occasionally downsizing to the 2x18650 config. I think all in all, Malkoff got it right.
One of the significant and often overlooked things about the Hound Dog, in any configuration, is that you can run it off primaries.
They do store less watt-hours, for sure. But, in an extended outage, or when you deplete all your 18650s, you can feed it 4 primaries. On low, the runtime should be tolerable.
This is important because most Malkoff lights do not run off 4x123 primaries. None of the M61 series (except for SHO IIRC as someone will be quick to jump in and point out, or maybe it was a one-time device), M61T does not, neither does M361 nor M61HOT.
M91T does and of course so do the other permutations of Wildcat, etc.
I kinda like the idea of using *either* two 18650s *or* 123s. All in the same device. That gives the device incredible flexibility.
thermal guy
ny
There's nothing I don't love about my HD18650. Just realized I could run it on a MD 3 body and use 2XAA! Run time is measure in days and it makes it that much more versatile. Perfect BOB light
Modernflame
Dirty Dirty South
Wow, I had no idea. That's one of the hidden benefits of Gene's simple designs without low voltage protection.
archimedes
CONUS, top left
I wonder if there might be enough interest for Malkoff to do a run of "MD3AA" tubes ?
Nah, I doubt it ... but I want one, and would buy one.
etc
Northern Virginia
I would buy what one might call MD6 -- a 6x123 body or 3x18650 body -- all in one piece without having to buy an extension. Whatever name you want to assign to that.
MD2=1x18650 or 2x123
MD4=2x18650 or 4x123
MD6=3x18650 or 6x123
thermal guy
ny
Yep our expert on Malkoff runtimes is doing a test for me so we have real data but I'm doing one with just regular Duracell AA alkalines and it's past the 70 hour mark! Probably only 5 lumens or so but because of the way the beam is on these it is still VERY usefull. Can easily walk with it and still throws 15 feet or so.so with the MD3 body you can run a 18650 with a spacer 2-123's with a spacer. Or 2 AA Only problem is with using the 3 cell MD3 body with the 18650 head you CAN run 3-123! And that would be bad.
Modernflame
Dirty Dirty South
:poof:
Yeah, my Hound Dog 18650 doesn't play lego with the other Malkoffs. Still, nice to know I could run it on 2xAA in a pinch.
As for the Super, I had one and enjoyed it but ultimately sent it on to a better home. I live in wooded part of the country, so even when I'm walking around outside, I rarely have an unobstructed view of more than 100 yards or so. The other Hound Dog breeds are a better fit for me.
etc
Northern Virginia
Come to think of it, MD6 that I made is twice the length of an MD3 body, since it takes twice as many cells as MD3 body that we know runs well off 2xAA.
Well, on low anyway.
Therefore, it would be logical to try to run it with 4xAA cells, on low obviously and see what happens. 4xAA pull 6 Volts of course.
I do wonder if they will be long enough but theoretically it should work. I also know that the Z41 tailcap is a little tighter than any clicky, i.e. can tolerate shorter overall length.
etc
Northern Virginia
To reiterate, the MD6 configuration is not exclusive to the Hound Dog.
It should also work well with the 'regular' HD as well as with the M91T that has the same voltage specs. If M91T can run on 4x123, it can run on 3x18650.
And if the MD6 body can fit 4xAA without an issue - you can adapt 4xAA Eneloops to run the 18650 Hound Dog mated to the MD6 body, if I am not mistaken voltage wise, it should add up right to about 4.8V and sag under load to where a normal 18650 would be. 4xAA Alkalines are at 6V which is roughly equal to 6V you get from 2x123 that's also acceptable nutrition for the 18650 HD, so either way, that's works out fine.
If it's the end of the world and you are stuck in a warehouse full of AA cells but not a single 18650, and you have the 18650 Hound Dog *and* an MD6 body, you have enough lumens until the end of time.
FiveMega made the 3xAA body a while back.. it has not been a glorious hit. I think I've seen just one other example floating around here.
I've had one for what seems 8 years, never used in any serious capacity, just did a few test runs. It's huge - as in "long", not possible to EDC but the voltage is lower than a single 18650. So it runs all Malkoff modules under powered unless of course you pick M31 series. Then it works well but so does the much more practical 2xAA body.
I wonder if an MD3 Hound Dog Super will fire up on low using say 2xAA Lithiums. The current requirements are not that high.
But I think I would buy at least one MD6 body to mod one of my 'regular' Hound Dogs. The Super however makes more sense to mod since its voltage requirements are greater.
What would be really cool is a one-time manufacture of an MD6 Super Plus that runs on 3x18650 *or* 6x123 cells, uses a one-piece body but I think that will create more problems than solve in terms of not being a commercial success. Still, an interesting proposition. Perhaps if the lumens are bumped slightly, it might be competitive versus SOBs.
If my math is correct, the current drain on Super Plus is roughly equal to that of the 'regular' Hound Dog. Lower drain means better runtime.
thermal guy
ny
My 18650 is running on 2XAA alkalines. That's just 3 volts.
etc
Northern Virginia
I am assuming on low and what are the lumens it's generating? Must be pretty low.
Yeah, it will run on 2xAA but 3xAA is better. Better still is the 4xAA configuration which seems like the optimum voltage given AA requirements.
It's also huge.
thermal guy
ny
It's also huge.
It will run on low and high. Much lower output of corse. But because it throws so well it's very usable
thermal guy
ny
My HD 18650 has now been running on low for 80 hours! Not taking about moonlight kind of light. It's putting out plenty of light to easy see your way at night. This is nuts.
