Dingle1911
- Joined
- Dec 27, 2011
- Messages
- 438
My current favorite is 4 mode H/M/L/Moon (default) with no memory.
Based on my Zebralight headlamp's settings, I guess I'm a fridge burglar (H-Med-Moon).
Is this programming change still a possibility?
Grizz
I like how my Alpha is now. Flucero28 reprogrammed mine.
Firefly, L, M, H. Hybrid memory.
Remembers last mode used, but will revert back to firefly for mode change, no matter what level prevously used.
This is the ideal setup.
My question of is the programming change a possibility, wasn't worded very well.
Do you, Jason, foresee the possibility to order a Blue Label light programmed in a different than stock manner?
Sure, a fellow CPF member may be able to mod the light (different emitter, altered program, etc), but I'd prefer it be done by the manufacturer, if at all possible. That would allow it to be fully supported from a warranty perspective, and also wouldn't affect resale value (though I've never sold a light and don't plan to).
If it isn't possible, I've got no problem with the stock programming.....just providing some hopefully useful programming feedback.
Grizz
My best custom firmware ("lupodrv") for the NANJG linear drivers can be reprogrammed by the user with whatever modes you want You enter programming mode by 8 very fast taps (half presses) and then it allows you to reprogram the current mode with a new brightness (from a ramp of 16 visually linear levels), strobe or beacon, or to add a mode, or to remove the current mode (i.e. you can change the number of modes; max. 6), or to change memory type between no-memory, classic memory, or short-cycle memory (memory, but jumps to 1st mode when you change modes again, I think some people call it hybrid memory here). 5 very fast taps en-/disable mode locking, i.e. it won't change modes any more, good for tactical/signaling purposes.
Can the UI be L/M/H with 0.5sec memory?
I still can't figure out why would someone do a 2 sec interval.
