When did black conductive anti-static foam stop being conductive?
PhotonWrangler
In a handbasket
Tonight I ran across a good sized chunk of what looked and felt like black conductive anti-static foam, the stuff that's impregnated with carbon. I wanted to confirm whether it was the real thing so I pulled out my VOM, put it on a high resistance range, stuck the probes into the foam, and... nothing. So I located a nearby integrated circuit that was sitting in a little rectangle of what was supposed to be conductive foam, put the VOM probes on it, and... nothing again.
I distinctly remember that I used to be able to get a fairly low resistance reading when measuring across that crunchy black foam. Now I'm starting to doubt whether most of my anti-static chip storage foam is real.
:wtf:
louie
Seattle
I wonder if you need a low DC resistance for static safety? What happens if you use probes on a static-safe plastic bag?
Rapidly looking at a random spec sheet for static dissipative foam, I see a spec for surface resistance of 10E3.
I suppose it's also possible some products did have a low DC resistance.
Dave_H
Ottawa Ont. Canada
Two basic types of foam: pink (usually) polyethylene which is anti-static but not conductive, and the black stuff which is conductive. I picked up a piece of the latter which has been around for awhile (decades) and it crumbled, so it must dry out or otherwise break down (made a mess).
I checked two small pieces of 1/4" black foam, old but still pliable, with ohmmeter. Both showed 10k-15k ohms with probes about 1" apart, which seems OK.
Dave
PhotonWrangler
In a handbasket
Dave
Thanks Dave. Yes, the old carbon foam did have a tendency to crumble and make a bit of a mess. Maybe there was a change in it's composition because of this, trading off conductivity for mechanical stability. All of my recent purchases of thru-hole chips come in anti-static plastic tubes so I don't have many samples of foam to compare against.
Monocrom
NYC
Plenty of companies will quietly tweak an existing product, but not mention it to the Public. Wondering if that was the case here.
