Pounsfos
Howdy all
I've built alot of dolphin torch leds with big battery packs etc...
My next build I want to go big and have decided to go for an xhp 70.2 over driven to put out roughly 60-100w (yes that is some amps)
I have chosen the 6v version as it seems to be more compatible with drivers etc... but this is my biggest problem I'm having, I know mosfet drivers can dump some amps but how would I go about limiting the amps going through the drivers or to the led.
My build will probably have a 3s5p lithium pack behind it where the cells can do 10amp discharge so will easily be able to dump 30+ amps into this led, which I dont want, am I over thinking it or do mosfet drivers have a limit to how much amps they can "put through"
Also if someone can point me to a driver suitable for my needs, that would be awesome, size doesn't matter as it's going into a custom box.
Thanks in advance for your input and suggestions
Scott
Scott
