I'm pondering getting a 200mW green laser from DX.
If I understand correctly it won't generate that much power from two AAA cells. It will from lithium AAAs, but only for a very short time before voltage sags.
Now, I'm thinking of connecting an external battery of significantly higher capacity. Say, a 2s3p pack of NiMH AAs, which should be able to handle the 800+mah draw without batting an eyelid.
Would the laser be able to consistently give out 200 mW in that configuration?
Also, what is the voltage range? (if it can run on 4 volts a lithium cell might be a good idea...)
Thanks.
Edit: oh, and if you could tell me where to find protective eyewear for cheap it'd be good
