2ND Run M*gCharger G4 Ceramic Socket by Fivemega
Status
Not open for further replies.
fivemega
California
(AVAILABLE)
Continue from here
Please allow 7 days to ship
2Nd Run
Hi folks,
Here is second run of M*g Charger ceramic slug with some improvement.
M*g Charger is favorite flashlight of many people specially when used with WA1160, WA1111 or PH5761
Unfortunately, stock bi-pin slug of M*g Charger is plastic and won't take that much heat produced by super bulbs.
I have designed these ceramic cast bi-pin slugs which will take many G4 bi-pin bulbs such as Welch Allyn 1111, 1160. 1274, 1185 and ....
No more smoke, micky mouse shield, bulb lifting or bulb limitation. An allen wrench (included) will secure the bulb with set screw. (Do not overtighten)
Excellent choice when used with Extension tubes and M*g Charger Throw Master.
You will need to remove switch assembly from flashlight then replace slug.
Please see post#2 for R&R
Will also work in standard switch of any incand M*g "D" and M*g "C"
Price
Ceramic slug $38
WA1274 $6 each (AVAILABLE)
6V G4 bulb $2 each (AVAILABLE)
Shipping to States $6
Internationaly $14
Please post your order here and paypal note including your user handle name right after you pay.
for 1 ceramic slug
Paypal: [email protected]
Please PM me for other type of payment.
Please see:
MC MOP Aaluminum Reflector
MC 2.5" Throw Master
Please find link of my other products here and click on each link you are interested.
(A V A I L A B L E)
fivemega
California
Question?
Re: M*g Charger Ceramic Slug by FIVEMEGA
Remove bezel/reflector/bulb. Unscrew and remove positive (front) charging ring from switch housing. Remove switch boot. Press switch (to "ON" position) and hold while you push switch in from front. Switch assembly will come out from back side of housing.
Using 2mm (5/64") hex wrench, remove 2 roller screws and replace slug. Make sure spring sits properly.
When installing switch into housing, push and hold switch to "ON" position using a pick.
http://www.youtube.com/watch?feature...&v=Jr1jcCRirEI
will these slugs work with regular d cell m*gs???
Yes, these slugs will fit M*g "D" and M*g "C" and work perfectly.
Can these slugs be modified to accept 623 bulbs?
Short answer is no. Even if 64623 fit in this slug, fillament of bulb will be way beyond reflector focusing range. Not to mention bulb opening is also another issue.
M*gCharger switch assembly and tower is made of metal but M*g "C" and M*g "D" are made of plastic. Temperature of 64623 will melt plastic tower of switch.
what are the differences between this slug and a common mag slug with your gold bi-pin adapter installed?
These slugs will work with MC, M*g C and M*g D but common mag slug is only for M*g C and M*g D
Does anybody know which An allen wrench is needed to remove the MC-slug [or socket]?
5/64" or 2mm
This is same allen wrench used for M*g "C" or "D" switch.
bridgman
Bowmanville, Ontario Canada
Paypal sent...
$156 sent for:
$36 for #22 MOP 11mm (for MC)
$76 for 2 ceramic slugs at $38 each
$12 for 2 WA1274 bulbs at $6 each
$20 for intl shipping per PM discussion
$12 for intl insurance
MC MOP reflector is from a different thread but I don't have privileges to post there.
Thanks !!
Status
