Buckeye
I'm not FM, but no, the pin spacing is different between the 1499 and the 1111.
Thanks BSBG. That was the info I needed.
It's a 11 volt, 2 Amps bulb which runs well with 3 protected or IMR 18500 cells.Can't find much info on this 22w axle bulb.
Will it on 3 imr 18500 cells. Which cells would you recommend ?
Went to swap in the higher power bulb and the o-ring that keeps the bezel well secured to the head tore apart, the large o-ring.
Don't worry, I will send you another one.
Edit:
In the mail.
