will these work with any Surefire M series head? or similar head m series style?
I take it they wont work with an M6 tail?
any other switch options other than a McClicky?
Since threads are M head compatible, you can also use your [size=+2]KT4[/size] head.
===============What you get is: Body, [size=+2]Tail cap[/size], Head, Bezel, Switch boot and all needed o'rings.
Tail cap is designed to work with either option B of [size=+2]these[/size] switches or McClicky with adapter (Optional).
Inside diameter is about 26.80mm (1.055") and too small for even 2AA side by side.Is there enough wall thickness in these bodies to bore 3 channels inside to allow 3 AA cells to fit in side by side?
Is there a list available which bulbs you can drive in this sweet thing and how the runtimes are? I'm thinking about either this here or the 3x18650 Version
