Hi Greg,
First thing about Nichia UV emitters is that if you need a relatively clean 365nm peak emission, then you're on the right track. Though I'm not sure 365nm is the ideal choice for blood tracking. I might be mistaken, but usually higher UV wavelengths or even visible blue (415-455nm) with orange cut-off glasses might work better. (No experience with hunting/tracking, but I have an interest in UV photography and forensic lighting.) Second thing is that if you manage to source Nichia UV emitters, they practically cost an arm or a leg.
As
DellSuperman has mentioned, there are easily available and relatively affordable mounted UV emitters and P60 drop-ins. If your purpose is not dependent on a single peak wavelength and do not need the best quality UV output, then those are good choices.
There's really no benefit in overdriving UV emitters apart from making them go
. E.g. The Nichia NCSU033A is rated at 450mW and I(F) of 500mA. If it is high output applications Nichia's NCSU333A 365nm flavor is rated at about 3.6W. And no, you do not want to know how much one of those emitters cost.
My point is, go for what you need. The commercial UV offerings from manufacturers e.g. Nitecore, Streamlight may suit your needs.
