I wanted a really deep red LED, so I purchased a $4 - 5W and the description said 740-745nm, while the envelope it came in said 730nm, unfortunately, I have no idea of how to measure, however, it would be considered and is considered to be infrared -- well by far it is not.
1. If you google human vision spectrum you get a complete cutoff at these wavelengths in some charts, and a little beyond that in other charts, none of the charts actually represent the human vision that well, it is mostly guess-work type deal.
2. I came to this conclusion because I used the front iPad camera as well as rear, and both cameras showed about the same brightness, I intend on checking again once it gets darker, the reason it should have been different if this was infra-red is that the rear camera has a very good infrared filter, front camera shows infra-red as bright purple (try your remote control).
3. Description None of the computer screens could ever display this light, and I doubt any camera apart from film could either. If you have seen the latest sportier Mercedes AMG like 2019 models (I will update with a specific car model when I see one again) -- I believe they use this wavelength for their tail lights. I have been mesmerized a few times what is that new red tint Mercedes is using, and by pure luck this is exactly what I got in the mail today.
If you ever saw the faint red glow of 820nm IR camera -- I would say it is similar tint red, but without the IR part, and much much brighter than IR (to the eye).
4. It does not look very bright unless you look straight into it, and it does strain your eyes if you look into it your irises will contract, illumination per watt is lower than that of regular 630-640nm, however ~650nm looks orange in comparison to this, this looks evil.
Suffice to say -- our eyes are not sensitive to this wavelength, but it is definitely red and not infrared.
Plan: I will leave the flashlight I frankensteined this LED into running until its almost dead, and when it is very dim I will test it with the front iPhone camera to see if there is any "white" looking residual IR light coming out of it.
P.S. If you shine this LED through a very deep blue glass filter -- it makes that filter completely transparent and see through:thinking:
