bikeNomad
I've been looking at Linear Tech's LTC4059 tiny little 900mA battery charger chip (LTC information) and it looks like this might actually be a simple way to get a low-dropout current regulator in a very small package.
And it's easy to put this on a single-sided 10x10.5 mm board (or double-sided, with the bottom all ground):
I haven't tried it yet, but I think I will soon.
The circuit has an extra resistor on the EN/ line for remote on/off; if you don't need this the R1 can be eliminated and EN/ tied directly to GND.
The current is programmed using RPROG; this would also make it easy to switch between different brightness levels.
