Angeloflight
- Joined
- Jun 14, 2017
- Messages
- 4
I have another question when I use x45 why does the lens get a little foggy, like moisture inside? is thus normal?
Turn it down (Lower brightness) or turn it off, simple as that.OK I have another question. I'm kinda new to all this and my X45 6500k will be here today! How Do I cool the flashlight when it gets hot? What's the best way? Thanks.
The relationship between perceived brightness and heat produced is not linear. That is to say... turbo makes much more heat than high, which makes much more than medium.
Edit: just noticed noboneshotdog addressed this in the last reply to the other question. Sorry NBHD.
Toggleing through all the modes including high on 9000 lumens and turbo at 16000 lumens had the red indicator light indicateing that my batteries were low within 30 minutes or less it seemed?
can anyone recommend me some batteries for my new x45 please,very new to high powered flashlights.a link will be much appreciated. thank you
does protected/unprotected matter?
It is inconsistent. The X65 that has "only" 12000 Lm is almost the double in size of the X45 that has 16500Lm! You cannot hold the X45 when in Turbo Max for more than 1 or 2 minutes. The torch becomes so burning that you cannot even press the metal button! This would be a good 4000Lm light. Turbo and turbo max are useless and are implemented just to make this simple torch more attractive. Other contradiction: The light needs high drain batteries for better result but wants protected battery - that have usually 10A - to be safer as the cells are in series. This torch would need an internal fan like the New Olight X9 or the Powertac 10500Lm.
Also, in addition to what grioces indicates in the post located above this post,Interesting observations.
The X45vn mod is 25,000 lumens. Twenty-five thousand L words. For how long, before depletion, melt down or uncontrolled fission? I will have to buy the Vinh mod version and find out for myself.
maukka: Thank you for your detailed and valuable review.
Also is the build quality of the X45 close to the X7? I like that the X45 is a little less expensive than the X7 ( all up ready to use price).
Thoughts, Ideas?
I need a good light and have been studying these lights for several months....tia!
in addition to this topic thread that we are in now, there is this: http://www.candlepowerforums.com/vb...ight-Review-(4x-XHP70-4x-18650-16-500-lumens)Beyond the "fun with flashlights" thing... there is a serious side to this. I am in need of flashlight for hurricanes and other issues. I have 4 small Olights, but nothing in the realm of a X7 etc. After reading and reading and reading... I have narrowed it down to the Acebeam X45 or the X7. I like the X7R, but not being able to swap out the batteries in addition to the leaky charge port takes it off the list for ultimate survival tool.
Question : Drop forged steel drops the X7 from 50 ft and freezes it etc. Does any one know if the Acebeam X45 is almost as durable?
I have been looking for links to the Acebeam X45 here but no luck. Would someone be so kind as to copy paste links so I can learn as much as possible about the X45?
