Acebeam X70, in the works for early November?
mortuus
up at 60k lumens now the x70 and over 1km throw, impressive the imalent is already beaten.
mortuus
Its official now, 60k lumens!
Features:
Utilizes 12 x CREE XHP70.2 LEDs plus a CREE XHP35 HI LED with a lifespan of 50,000 hours
Max 60000 lumens output
Powered by a built-in rechargeable battery pack combining 8x18650 batteries
ECO Mode
Ultra Low: 625lms, 24 hours;
Low: 3250lms, 5 hours;
Med: 8000lms, 2 hours;
High: 15000lms~11000lms, 40 minutes + 15 minutes;
Turbo: 35000lms~15000lms, 2 minutes + 1 hour;
Strobe: 10000lms, 3.5 hours;
Power Mode:
High: 25000lms~16000lms, 8 minutes + 48 minutes;
Turbo: 60000lms~15000lms, 55 seconds + 50 minutes;
Battery Indicator:
When the voltage is below 12V, it is Red light;
When the voltage is below 11.5V, it is Red flash light;
When the voltage is below 10.5V, it is powered off.
Charging:
X70 can be charged by the equipped AC charger or DC Car charger.
The built-in power indicator RED means in charging, and GREEN means fully charged.
Charging current is 2.5A, and charging time is 3 hours.
External Head Dissipation Fan Battery Indicator:
When the indicator is GREEN, the battery is full capacity;
When the indicator is RED, the battery needs to be changed or charged.
Max runtime: 24 hours
Max beam distance: 1115 meters
Size(mm): 280.85 (length) x 116.0(head dia) x 51(tube dia)
Weight: 1819g (with battery pack)
Peak beam intensity: 311000cd
Waterproof: 10 meters submersible
Aircraft grade aluminum body structure with premium type III hard anodized anti-abrasive finish;
Ultra-clear tempered glass lens with anti-reflective coating, which achieves a 98.3% light transmittance;
Intelligent highly efficient circuit board design for max performance and long run time;
External heat dissipation fan system design for more effective cooling of the flashlight body;
Intelligent temperature controlled light output for user safety;
Smooth reflector for max light output and maximum highly focused beam distance;
Streamlined body design with tactical knurling for firm grip.
HARDUSVD70
Just recieved my DHL tracking number few hours back for my Acebeam X70!!! Cannot wait for this parcel.
Like to compare it to the Imalent MS12.
