Hello Chevrofreak and Aestryker,
I have checked out various technical information on the Heavy Duty batteries available from various manufacturers. The all seem to publish similar data to what I have shown.
For example, Energizer lists the capacity of an AA Heavy Duty battery as 1.100 Ah with a 0.025 amp load. If you look at the constant discharge graph, this works out to around 30 minutes at a 0.5 amp load. The Ray O Vac's I tested ran for 31.6 minutes which tells me that the Energizer's are very similar to the Ray O Vac's. In this chemistry, I suspect that the other brands would be very similar.
My purpose in testing the cells, was to demonstrate the performance under loads that we would see while using our lights. In this context, the Heavy Duty batteries do not hold up very well at all. The Ray O Vac Heavy Duty battery gave me about 32 minutes of run time with a steep voltage decline, where the Ray O Vac Alkaline battery gave me close to 180 minutes with a much more stable voltage decline. Looking strictly at run time, you would end up changing the Heavy Duty batteries about 6 times to get the same run time from one Alkaline battery. I suppose that a cost comparison could suggest something a bit different, but I'll stay away from them for my applications.
Now, if you have a light that only draws 0.025 amps, you might be able to get the rated performance from them. On the other hand the Alkaline batteries with 2.6X the capacity (in the same size) would give you even longer run times.
At any rate, I doubt I will be testing any more Heavy Duty batteries.
Tom
