I have tried a few different solutions for mounting a weaponlight on AR-15's, but so far I have not been thrilled with any of them. Budget is part of the problem as indicated below, I know I can go with a high-end purpose-built light but I would prefer to stay within my budget right now. I have run a Streamight TLR-1S mounted on the top rail and a couple different .84"/1" lights in ring mounts. The Streamlight was decent but controls and brightness/throw were not to my liking for use on a carbine/rifle. In addition I prefer to keep it on my pistol so I'm looking to get something more ideal for my preferences if possible.
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest!
Up to $200
3) Format:
I want a mounted light, specifically, mounting on an AR-15 with mid-length Magpul MOE Handguards. I may change out for a configurable free-float later, but will have more flexibility for mounting in that case.
4) Size:
I don't know/I don't care.
5) Emitter/Light source:
I don't know.
6) Manufacturer:
I'm a tinker so willing to do assembly myself, but not opposed to an out of the box solution.
I don't know/I need more information on power sources.
I want a separate/stand-alone charger (this involves removing the batteries to charge)
8) How much genuine out the front (OTF) light do you want/need?
I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
5-20 yards/meters (check out a noise in the backyard)
10) Runtime
30-60 minutes (I have plenty of batteries just ready to be changed)
11) Durability/Usage
Very Important (Camping, Backpacking, Car Glove-box).
I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
I want a tail mounted switch (found on the majority of today's high end lights).
A simple on-off with only one output level is fine for me.
14)Material/Finish/Coating
_X___Plastic/composite body (this may limit your choices significantly).
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
15) Water resistance
__X__IPX4 (Splash resistant)
16) Storage conditions
In house (temperature/climate controlled environment)
17) Special Needs/extras
N/A
Up to $200
3) Format:
4) Size:
I don't know.
6) Manufacturer:
10) Runtime
N/A
