ArmyTek Partner A1, A2, C1 Series (XP-G and XM-L, AA and CR123A) Review: RUNTIMES+
lightmyfire13
Thanks for your awesome reviews Selfbuilt! Since discovering your reviews, I have never bought a light without checking out your reviews..
Wondering if any one has tried out the A1 Limited Edition XML-U2- claims 390 Lm with a AA 45 mins and 700 Lm with a 14500.
Still only 2 modes...
Thinking of ordering one....just wanted to see if any one had tried it out though...
Got one a couple of weeks ago ...very bright on eneloops beats my sc52 try n put pics up later
alltoclear
Does the Partner C1 comes with a buck/boost driver like those found on the wizard pro??
Ageemos
Wondering if any one has tried out the A1 Limited Edition XML2-U2- claims 390 Lm with a AA 45 mins and 700 Lm with a 14500.
It would be great if somebody would test these claims. If they are true or not.
Brunberg
Just got one of these, A1 XM-L2. Weird that my lamp is with normal optic, I understood that all XM-L2 models are with that honeycomp-type optic? I even opened the head and measured the led with "mauser"(what is it called?) and it was 5x5mm, XM-L2.
radu1976
Red Deer, AB, Canada
Selfbuilt, you got a 1:18 hrs runtime on HIGH for A2 XP-G using ENELOOPs.
My XP-G2 A2 run for 1:45 hrs with 2,000mAh ENELOOPS until the step-down and for 2:15 hrs with 2,450mAh ones.
Is it possible I have an overachiever ??
selfbuilt
If they have kept the drive level the same, I would expect a slight increase in runtime on current XP-G2 (due to the presumably higher output bin selection over time). Note that my runtime measure is only time to 50% - it would be longer if you are counting to time to ANSI FL-1 10%.
But as a general rule, an output overchiever would typically mean an output underachiever if everything else stays the same. The original circuit was already very efficient, so I doubt they could squeeze much more out there. Of course, there is a bound to be some variability due to the specific emitter/circuit/battery, etc.
dJippe
Does anyone know is this "xm-l2 limited" version with updated driver/user interface without that 7minutes delay?
stanleywen
I sold my Partner A2 XM-L and bought a A2 XM-L2 (Limited Edition). The 7 minutes delay is still there, and there is no 3rd mode.
But the limited edition uses a clear TIR optic. The beamshot looks similar to the XP-G edition.
D6859
Finland
I was wondering if it's possible I got an XM-L2 version with clear lens but it seems so! So can I trust it has the runtime of XM-L2 and the throw of XP-G edition? :)
