Hello, I bought this flashlight and I like it a lot. The only issue is the charging which seems strange sometimes... Even when the battery is under 4V, after connecting the charger plug (the tail cap unscrewed by 1/4 turn) it sometimes flashes between red and green light and I need to twist the plug a little or unplug few times to make it work. Also the charging current seems low, it is approximately 200mA. Does somebody here have the flashlight and can measure the charging current for me?
Hi jirik
I answer even if it's been a long time because it can be useful to other users.
When I bought the first Armytek Wizard I had the same doubts but then later I realized that this is normal.
(I bought more than one Wizard and tried various cables)
After unscrew the tailcap to 1/4, you must connect the white cable and then turn it slightly to see the red color appear - then avoid moving the cable until the end of charging.
The charging current is low, it is made of the tests, it is "high" if you unscrew the tailcap a little (in this case I measure 0,23 / 0,27 A) - if you unscrew too much the tailcap the charging can happen again but the current will be lower (0.15 / 0.16 A)
The magnetic charging is not perfect but if you are not in a hurry it is very convenient.
(sorry for the bad translation)
