ASTROLUX 6th Anniversary Limited Edition WP3 Titanium Alloy Group Buy
freeme
Group Buy
Limited to 15 coupons
LEP 562lm 2952m 21700 Rechargeable Flashlight
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: $289.99 (usual $499.00)
Freeme's Coupon: Reply on this thread
Can't wait for our reply??
Special Price: $319.99 (usual $499.00)
Coupon: BGWP3T
Description:
Astrolux® WP3 LEP light source has high energy density, and then passes through a special lens reflection system to form a dazzling light column. High and low brightness modes are adjustable, simple and practical. WP3 LEP search light throwing distance up to 2.6 kilometers! , Luminous flux 562 lumens, light intensity reaches 1750000 candela, comes with one 21700 rechargeable lithium ion battery, high-quality drive circuit with temperature control, constant current drive and ensure that the flashlight will not overheat. It is designed for special lighting.
Flashlight Specifications:
NameAstrolux® WP3 2645m Long Shoot LEP Flashlight
MaterialTitanium alloy, black hard anodized surface
Reflective systemAcrylic lens
Light sourceSpecial LEP module, wavelength 450-700nm, lifespan about 10,000 hours
Distance2952 Meters
Intensity2,180,000CD
ModeSingle Click: Low - Medium - High
Triple Click: Strobe
Long Press: OFF
Lumens95lm - 562lm - 562lm
Battery1x 21700 or 1x 26650 li-ion rechargeable battery (21700 Included)
Impact Resistence1.5m
WaterproofIPX6
SwitchBode side, 50,000 press life
LensDouble coated tempered glass lens
WeightAbout --0g (without battery)
Size (±0.5mm)(head diameter) 59.5mm, (body diameter) 34.5mm, (length) 187mm
Battery Specifications
ItemAstrolux® E2145 21700 Battery
Typical Capacity 4530mAh
Minimum capacity4500mAh
Nominal voltage3.7V
End-of-discharge Voltage3.00 V
Max Discharging Current28A
WeightApprox:70±2g
Operating temperatureCharging:0℃~45℃
Discharging:-20℃~60℃
Storage temperature-5℃~35℃
Storage Humidity≤75% RH
Size, Diameter22±0.5mm
Size, Length71±0.6mm
Net weight70±2g
Features:
- High efficiency constant current drive circuit, no noise and no PWM
- Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating
- Reverse polarity protection
- Low voltage prompt function
- Battery over discharge protection
Package Included:
1 x Astrolux® Limited Edition WP3 Titanium LEP Flashlight
1 x Astrolux® 4500mAh 28A 21700 Battery
2 x Spare waterproof O-rings
1x 21700 to 26650 battery conversion tube
1 x Lanyard
1 x User Manual
