I have an small amplified speaker system that I am making into a portable system. The adapter that came with the speakers is 12V 2A but I figured out that unless the Vin drops below 6V, the system works fine; the system automatically turns off at 6V. I don't notice any difference in sound quality at lower Vin. At 9V the current fluctuated between 300mA and 500mA according to the bench DC power supply.
That said, i bought an 8xAA battery holder and attached a barrel plug to it. This plug came with 18AWG wires already molded on which I cut to 3ft. I also put a rocker switch on the positive lead in case I want to disable the battery pack for whatever reason.
The batteries I'm using are 8xAA Eneloops, but I'm not sure of their age. My Maha charger indicated between 1800 and 1870 for all 8 using the refresh analyze function and default 1000mA charge, 500mA discharge settings.
According to my digital multimeter, the current is fluctuates between 420-450mA using my battery setup. I ran the system continuously for 4.5 hours at a party a couple days ago and haven't touched it since then. Today, I've had the speakers running for about 30 minutes and under load the battery reads 10.0V and open voltage is 10.1V. I'm thinking this isn't right because the batteries should be depleted by now according to my calculations. How is this possible? My multimeter is a Radio Shack model from the mid-1990s if that matters.
Is it 9.6V under load or open voltage that I should consider the batteries fully depleted? I'm trying to figure out my run time right now -- I know that I should get at least 4 hours but not sure what is the maximum run time because I do not want to damage the batteries by over discharging them. Is this a legitimate concern or is it after some point the batteries the voltage under load would drop too much to power my speakers -- keep in mind automatic shut down doesn't happen until 6V which is 0.75V per cell.
I would like to add something to turn off the battery power below a certain voltage, but I feel like this would be overly complex for this application.
