thermal guy
Re: Battery Vampires - Lights that you can feed your "dead" cells to, listing..
I would not presume to debate logic with you my friend 😁
Yes it's "safer" to run cells down in a single cell light do to different cell voltage but the chances of something going wrong is close to zero even when not doing this if you run your flashlight completely dead with two cells that started the same there will a high difference in volts between the cells. [...]
I would disagree, in that even two cells with similar open-circuit voltage, can differ significantly in other factors which may increase the risks involved ( even if they have been "run together in the same light the whole time" ) .... To give just one example, is heat, as the battery closer to the emitter may have gotten much hotter over the course of use than the other one.
Hmm, I tried to parse that crazy sentence by TG above; I thought I knew what he was saying until ~2/3 through, then started thinking the opposite & gave up in confusion. So if Arch could figure it out, he's one up on me as well ...I would not presume to debate logic with you my friend
Peak is my answer for that. Output will eventually drop like a rock, but it will run just shy of forever.
I use the Logan 17500 (with a spacer)I looked, but can you recommend a specific model? Thank you sir!
Hello guys, I don't have time right now to read this entire thread right now (blame hurricane Dorian) but I am looking for a single 123A cell light to vampire my 123A cells. (Actually, I use single 123A lights to find out which one of the two or three cells in my P3X, P2X, or Charlie dropped voltage so much that my light went dim on me.)
Does the Malkoff MDC HA 1CR123 Neutral flashlight work okay for this or the Malkoff MDC HA SHO?
I am tired of my Surefires always dropping a cell and going much dimmer quite often. In fact it just did it again today, and I do not want to throw out 2 decent cells.
I used to use a Olight Baton for this reason but I sold it a couple months ago. Looking to upgrade to a nicer light. If the Malkoffs are decent and will drain a cell to a reasonable amount I will go that route.
