SuPpAvIlLiN
I'll go take a look.Do you have the I2/I4 or D2/D4? Not sure if they differ in length.
EDIT: The charger Says i2
I have the D2. The KP protectes will fit in this charger if you lower the cell straight in and not bottom then top. I'm not sure if they are longer than the i2 or not though.I'll go take a look.
The 5000k 5A is an N2 bin so the lumens will be lower. Here is the thing though, unless you have the two side by side you won't notice any difference since you will have nothing to compare them to if they are not side by side. In any case you will most likely notice the tint difference more than the very small decrease in lumens.
Loving this light. But I don't understand this flikkering. It flikkers on Hi mode for the first 5 mins when it seems my batteries are full I'm gussing. The weird thing is that it stops and does not come back for the rest of the run time. Than I charge the batteries, I didn't put them back in for around 5 hours later, but when I did it flikkers again only in hi mode for the first 5 minutes again and than stopped for the rest of the run. Anybody have a clue why this would happen? I hope it's not defective.
If these 2 simple things do not fix it I would wager that its a problem with the driver board. I'm actually not sure if Convoy has a warranty or not, I've never seen a statement. I will ask. Either way if it is a problem with the driver I can fix it for you. Simon made the driver boards available for purchase recently so I ordered a pair for just such an emergency along with my next batch of lights. They will not be here for a little while yet though. He said that manufacturing time on the batch I just paid for would be like 20 days.
ok, thanks Matt, seems everything is tight. Like I said, after the light is on for about 5 minutes the flikkering stops and does not return for the rest of the battery life. So I can live with the flikkering only in the one mode for only 5 mins. As long as it doesn't get any worse it really doesn't bother me too much. Was just curious if anyone else had it happen...I guess not.This is the first incident I have heard of. I don't know what would cause that, but I'll tell you what I always do when I encounter any issue with a flashlight.
1. I check all the movable contacts. In this case the ring that holds in the driver, and the tail switch. Just make sure they are tight.
2. Try another set of batteries. Preferably unprotected cells. There is always a chance especially when working with protected cells there is a defect here. If you dont have more 26mm cells even a pair of IMR 18650s rolled up in a newspaper should do.
Thanks for experimenting and posting. I kinda figured it was the batteries. I don't know much about different batteries and all so I just bought the ones that were sudjested along with the L6 on the site. I guess I shouldn't use these Keeppowers in case it's damaging the light. I'll PM Matt and see if anything can be done. Site says no returns on batteries but...I experimented with the L6 tonight by putting protected Keeeppower 5200mah cells in it and it would just flicker on high mode non stop. Switched back to my much shorter King Kongs and it was fine. Dented in a positive terminal on one of the Keeppowers I had to use that much force to screw the tail cap all the way on. Still works though.
These batteries have worked with no problem:I experimented with the L6 tonight by putting protected Keeeppower 5200mah cells in it and it would just flicker on high mode non stop. Switched back to my much shorter King Kongs and it was fine. Dented in a positive terminal on one of the Keeppowers I had to use that much force to screw the tail cap all the way on. Still works though.
