Buying incan bulbs is so tedious.
fyrstormer
Banned
Maryland, Near DC, USA
I've been on a Surefire kick for the past few months, and so I've been shopping for D26-compatible bulbs to act as upgrades and replacements down the line when the original bulbs burn out. At first I bought some D26-compatible bulbs from LF, but the reflectors were badly fogged; I tried cleaning them and it kinda worked, but I decided to buy some more instead, after letting them know about the problem. The second batch was also fogged, though not nearly as badly; apparently this is because their incan reflectors are several years old, so the entire stock is going to be re-plated to fix the problem in the future. But I can't use those bulbs anyway, because even thought I bought the same lumen rating as an old bulb I bought from them years ago, the new ones trip the protection circuits in my AW RCR123s. Then I bought some Surefire P61s and P91s; the P61s have wiggly bulbs, and the P91s also trip the protection circuits on my AW RCR123s. The P91s must also be a different revision than the first P91 I bought months ago, because that one worked fine with my AW RCR123s. However, that older P91 had a wiggly bulb just like the P61s I bought recently. The newer, more power-hungry P91s would probably be fine if I could get some soft-start switches; if I blink the switch several times in a row, I can get the P91s to light-up, but they overload the batteries when the filament is cold. But of course soft-start switches were discontinued long, long ago.
All I want are some 200-250 lumen bulbs that are focused properly, have clean reflectors, and don't trip the protection circuits on my batteries. Is that really so much to ask?
archimedes
CONUS, top left
I hear you, but it is a diminishing niche market, and sometimes I wonder how long we will be able to get any incandescent lamps at all ....
fyrstormer
Banned
Incandescent bulbs will never completely vanish, just like buggy whips haven't completely vanished. Incandescent bulbs are the only bulbs that work reliably and become more efficient in high-temperature applications, such as inside ovens and all different manner of industrial equipment. As for how long they remain available for flashlight use...I have no idea.
But the bulbs I bought recently were made years ago. Even then they seemed to be inconsistent quality, even from name-brands.
Personally I have to blame Surefire for this one. Their integrated bulb-and-reflector assemblies are drop-in easy, but they are more complex and expensive to manufacture and the bulbs can't be substituted as easily. My ASP TacLite uses a bi-pin bulb, and it has an internal focus-adjuster integrated into the reflector, so I can pretty much install any bare 6-7.2V bulb that I can find.
scout24
Penn's Woods
I would strongly suggest replacing the AW's you're running if you're trying to power a P91 on 16340's. Efest IMR's solved my double-click issues, as did using a bored body and running 18350's.
fyrstormer
Banned
Yes, IMRs work fine, but I really really really like having protection circuits on my Li-Ion batteries, especially when running "dumb" loads like incandescent bulbs. IMRs are unlikely to catch fire if over-discharged, but they will still suffer damage, and the protection circuit takes care of that concern.
Anyway, I'm fine running 16340s and getting the lumens out of them that I can -- my problem is finding a reliable supplier of consistently-good bulbs.
Bullzeyebill
CA
What I did years ago was to go with the SF P60 using RCR123's. With the better, newer RCR123's you will be getting close to your 200 lumens. In fact it is akin to the MN15 which does very well on two Li-ions.
Bill
fyrstormer
Banned
Wouldn't the P60 burn-out if I fed it 8.4 volts? I know the P61 does; I accidentally flashed one a few days ago when I swapped the bulb but forgot to swap the RCR123s for primaries. That was a real facepalm moment; at least LEDs don't instantly die when overloaded. I almost did it a second time today, but somehow I got incredibly lucky and the bulb didn't flash even though the filament got warm enough to glow in the split-second before I realized I'd made a mistake.
I managed to find a single P90, if that's what you meant. I think those might actually be more expensive nowadays than the P91s.
alpg88
yep i can't find wa 1185 anywhere anymore, gone from every catalog. i just keep my hotwires on the shelf, to remind myself of old days.
Minimoog
I have had similar headaches. 'Must have' setups from 10/15 years ago are now almost impossible to replicate. Even if you were to, there are no ready replacements. After stressing about it for a while and not enjoying the hobby (for me it was SureFire M6 rechargeable options) I looked at what WAS easily available now, and TAD Customs really allowed me to have fin with my SureFire M4 and E2e etc, and not worry about sourcing long unavailable parts.
Incan is great fun if you just roll with it. If you try to find rare and in demand collector items, then that is a whole different hobby as the finding outweighs the using.
I went a stage further. I looked online and found the cheapest and highest quality bulbs I could (ended up with 6 V, 10-15 Watt halogen) and these were pennies each, then I looked for light to fit them - plenty out there.
Good luck - but it was almost too late even 10 years ago to find many of these parts - and even harder now. If you want to have fun, take a look at what you can get, and don't stress about what you can't.
ma tumba
Russia
I know this is a flashlight discussion, but the paucity of bulbs is a broader issue. That is why I have stashed hundreds of hotwire bulbs for general lightning (20-100W range) before they got extinct
scout24
Penn's Woods
Pretty sure Bill meant P90 bulb. I personally just troll the 'bay for NOS bulbs in D26 format. It's probably a matter of time before TadsCustoms is doing something for them at the rate he's introducing new holders and bulbs, wouldn't suprise me if he came out with something like Fivemega's Sunlight bulb holder assemblies. I had quite a stash of P90's, MN15's, MN20's and LF HO-M3T's on hand up until last winter. Slowly rebuilding, there's plenty out there if you're patient. With member Alterman offering 2x18650 holders for the M6, it's back in my nightly dog walking rotation.
Edit- Have you considered an E2e with either LF buls, or the Tad's bulb holder setup? Find one with a reflector you like and drive on...
Lumen83
I run TADs bulbs in the A2 and E2. Those are cost effective enough to buy enough to last a lifetime. For the P60 style lamps, I have a handful of actual P60s stashed away and used in certain applications. But for the most part I've bought the cheap chinese lamps off the bay in bulk in the 3.7V and 6V format and they've actually been great. Have been running the same lamps in two 6Ps for 2 years without issue. Both see daily use and battery swap about once a week. I have the same concern that these lamps will disappear for good so I am buying all that I need now.
novice
...wouldn't suprise me if he [Tad] came out with something like Fivemega's Sunlight bulb holder assemblies...
Considering how many CPFers want something like this, and how useful they are, I think that Tad could definitely sell some replacements. He might be able to simplify the manufacturing by having a separate reflector assembly, that the bulb holder could then slide into (instead of FM's beautifully-threaded brass plug), and which would be held in place with a small Allen-head set screw, like FM's. I won't part with my FM unit, but it would be nice if more people got to experience inexpensive G4 base bi-bulbs running on Li-ions. Thanks to the time Lux Luthor spent testing bulbs and posting the results, all we have to do is buy some, and plug them in. The Hikari JC 5607 is somewhat unique, for example, in that it will run at both 7.4 volts (~764 lumens, for ~137 hours), and also at 11.1 volts (~3000 lumens, for ~1.2 hours), and I have seen it listed for sale for as low as $1.09.
fyrstormer
Banned
I was looking at the TAD Customs offerings. Currently I have LF bulbs for my E1s and they work just fine, but since getting an ASP TacLite and observing the ease with which I could fit aftermarket bulbs to it, it has occurred to me that I should stick with TAD Customs' adapters for my Surefire lights going forward. That way I could stock up on only spare bulbs and not bulkier assemblies that have an integrated bulb as the only truly consumable part. But first someone would need to make a D26 reflector that has a bi-pin bulb socket in the base -- and perhaps a set of rubber-tipped tweezers to grab hold of the bulb when it needs to be replaced, because there's no way to reach that far into the reflector with bare fingers without scratching or fingerprinting the reflector.
For the time being, I ordered some generic 9V xenon bulb+reflector assemblies off eBay to see if they are any good. They probably won't last as long as name-brand, but at this point all I care about is consistency -- buying bulbs one at a time from random sellers, with no idea what revision they are or whether they are only being sold because they didn't meet the seller's own expectations, is no fun at all.
Lumen83
I bought a bunch of 6V and 3.7V chinese knockoffs and all I can say is I think the beam pattern in the 6V lamps are far superior to Surefire's P60s. As for durability, I can't say. And, I would bet that Surefires last a bit longer and are much more durable. However, I've used these every day for over a year morning and night and they've held up to drops, extreme cold and hot, etc. So far, so good.
fyrstormer
Banned
That's promising.
The bulbs in those no-name D26 drop-ins look the same as the bulbs that TAD Customs sells, and the same as the bulbs included with my decades-old ASP TacLite. It seems very likely to me that they are all churned out by the same factory, or that the design is so standardized at this point that multiple factories produce essentially identical products. Why "innovate" (i.e. "change for no reason other than to claim intellectual-property rights") on a design that is known, reliable, and ubiquitous? So hopefully that means the no-name D26 drop-ins will perform comparably well also.
On a tangentially-related note, the more I use the old ASP TacLite I bought, the more I appreciate its adjustable focus and separately-replaceable bulb. I don't have to worry about whether I'll be able to find just the right bulbs to use in the future, because as long as they're the right voltage and brightness, I can just tweak the bulb position until I get the beam pattern I want. The Surefire design of having the bulb and reflector integrated is certainly easier to service in rough conditions, and therefore doubtless better for military use, but that isn't a concern that applies to my daily life. While some people in the past have put effort into modifying TacLites to hold Surefire P60 bulb+reflector assemblies, I find myself pondering whether it would be possible to fit a user-adjustable lamp assembly into a Surefire instead.
bykfixer
Dust in the Wind
Yes, you can user service a P60 but it has to be pre-cut bi-pin bulbs so that one of the pins is long enough reach the outter portion of the module.
Tads bulbs are nicely pre-cut and so are the Streamlight TL-2 bulbs.
But yeah, if you have a burnt P60 carefully take it apart and you'll see how easy it is to service.
A burnt SureFire bulb
fyrstormer
Banned
I'll keep that in mind. However, a reflector module with a bi-pin socket would be even easier. Hopefully TAD Customs will get around to making those eventually.
flatline
Tennessee
I find this conversation fascinating.
I have a small number of P60 or equivalent modules just because they came in lights that I immediately converted to LED, but I've kept one flashlight running incandescent. It never occurred to me that once I burn through the 3 or 4 modules I've acquired by accident, it might be difficult to purchase additional incandescent modules to keep this set-up running.
So are we now at a point where there are no new modules being manufactured and suppliers are just selling through old inventory? Or is it that new stock is still being manufactured but it's of such dubious quality that the old modules are selling at a premium just because they are of known quality?
Clearly I have much to learn.
--flatline
