Spent a lot of time on this site and with google search trying to find a conversation about LSD charging characteristics.
The advertising literature claims how long LSDs last in storage and having used AAA Tenergy Centura in TV remotes, I will agree.
Got a new Foxnovo FS-4 charger/tester and did a short writeup on Amazon mostly about Li-ion.
Just bought a set of (12) AA Tenergy Centura LSD rated at 2000mAh that were at a great sale price.
The charger runs in two modes ...when choosing 0.5 or 1.0 Amp rate for charging only, it will read out mAh to full charge at 1.42v.
When in test mode, it brings to full charge and then discharges at either 0.5A or 1.0A and measures discharge only under load, then brings to completely charged, and keeps the discharge measurements only.
So, although LSD are supposed to be delivered at full "pre-charge", most weren't. They varied from needing as much as 1200mAh to being nearly full.
First round of testing at 1.0A, produced measurements that were all over the map from 1100 to 2100..I was ready to send them back!
Second cycle saw significant improvement from >1500, while third cycle had all above 2100mAh and a few went to 2200mAh.
There is more than one review on Amazon that agrees with my measurements and some claimed readings of 2300mAh.
In conclusion...beat the specs and I am happy, but that isn't the point of this thread.
If these LSD are supposed to hold high % for long time, then why did I see such poor results as received?
Could the stock have been on the shelf for years?
Did the manufacturer not bother to precharge or cycle the new product at the factory?
In short, what conditions could enable such poor performance
Any comments would be appreciated.
So far so good and I will be field testing sets of four in scuba torches next week and will see how much drain after an hour or two at 0.70A rate (3.5 watt Q5 LEDs and they should last 3hrs) ...I will test them camping in the summer.
