Re: Programmable Incandescent Regulator 1 sign up-thread *accepting payments*
I definitely know the feeling.. have about 60 hotdrivers soldered up, the first batch out the door, but also assembled into the KIU sockets, at least you don't have that to look forward to.
My body decided *for me* that today was a day off, don't work too hard that you get sick, you won't save any time in the long run.
I solder up groups of 4 when doing HD.. i get the thrill of victory every 4 then.. it's a convienent size that fits in the vice (now the jig i made)... and the boards came on pannels 4 x 5, which i saw apart before soldering to strips of 4.
The jig i made is great.. maybe something like it would work for you.. I took a wooden block that was actually a 'pinewood derby car' blank.. cut off one side at a 10-15 deg. angle and on the flat side, i drilled holes in just the right places where i could put some 3mm brass rod that lines up exactly with the KIU holes on the boards.. just 3 pins.. so i just drop the board on and it snaps right on the pin.. it'll hold 1, 2, 3 or 4 boards in-line.
In your case with reverse side components, i would drill out holes covering the center of the board and you can put a board on either way with components on..
It saves me several minutes per group of four in assembly because it's instant to flip or move a board.. I solder all the 'east' sides of the resistors, etc, then i flip 180 deg. and solder the 'west' sides so i can hold the soldering iron the same way, it goes very quickly.. 4 per hour complete.. including testing and setting the voltage.
Check out the pic of the hotdriver
here didn't wan't to hog PIR space with my bigass picture.. and notice that all components but ONE capacitor have east-west alignment other than the trim pots... learned from experience with the last two soldering jobs that that really speeds up assembly!
Good luck, can't wait to see them, but we're all patient enough to have them done right so go get your beer it'll calm the jitters and you'll solder better.
-awr
