ViReN
This is a Review of NovaTac EDC 120 P, Full review is coming soon ...
NovaTac EDC 120 P
provided for review by www.novatac.com
General Description:Extreme Closeup
More...
Database, Beam Shots and some pictures will be coming soon... Keep looking this thread for updates...
_________________________________________________________
Update1: The Database has been updated, you can now utilize the compare lights feature.....
Update2: The BeamShot Comparison matrix for P2D vs NovaTac EDC 120 P is updated
NovaTac EDC 120 P
NovaTac EDC 120 P is a Programmable Series flashlight from NovaTac. It takes single CR123 battery, has Seoul SSC P4LED, Body is built of aluminium with hard anodize type III coating. EDC 120 P is water proof with O-Rings to 20 meters (not rated for dive). Its one of the brightest, its very strong built, high quality, medium size light. EDC 120 P is one of the most advanced single CR123 light available in the market. The maximum output of the light is 120 Lumens. NovaTac EDC 120 P has Advanced (uC) Microcontroller Controlled Buck Boost Drive Circuit, this enables operation of the flashlight on both primary CR123 Cells as well as the Li-Ion Rechargable RCR123 Cells. What's interesting is that you can program the flashlight according to your preferences.
Light Features:
- All light levels can be programed to suite your requirements
- Can take various CR123 sized battery ranging from Primary Lithium to Li-Ion cells
- Polycarbonate lens with AR coating
- Seoul SSC P4 LED
- Buck-Boost Advanced Regulation (uC) Microcontroller Controlled Drive Circuit
- Flat Tail Cap Switch allowing 'Candle Mode'
More...
